What PSIs do you guys run in your tires?
Old Mar 25, 2007 | 02:02 PM
Jee_35's Avatar
Hey guys, I just got some new Toyo's on my car, and I noticed that the PSI on the tire says 50, but when I had them installed at Mr. Tire, they only inflated the tires up to 35 PSI's. They said that it was the ideal PSI and that anything close to 50 would just wear and tear the tires faster.. Anyone have any input? thanks!
Old Mar 25, 2007 | 02:04 PM
hai109's Avatar
50 is the max PSI...Ideally, it's 35 PSI...You can check you door jam and it will tell you what the manufacture recommends....
Old Mar 25, 2007 | 03:32 PM
GuyLegend's Avatar
For the 17's, Infiniti says 30 psi. For 18's (19's too I think) it's 35.
Old Mar 25, 2007 | 03:46 PM
Nismo G's Avatar
I run mine at 36 PSI
-sean
Old Mar 25, 2007 | 04:20 PM
G35 Mass's Avatar
32.5 on stock 17's w/ winter tires
Old Mar 25, 2007 | 11:46 PM
SilverII's Avatar
35f / 33r
Old Mar 26, 2007 | 01:09 AM
G35Luv's Avatar
47 psi's all around.
Old Mar 26, 2007 | 11:54 AM
ISMSOLUTIONS's Avatar
38 in front
36 in back..
Old Mar 26, 2007 | 02:44 PM
Jee_35's Avatar
thanks for the help guys, does it matter if you have aftermarket wheels? cause I'm running the SF challenges, again thanks!!
Old Mar 26, 2007 | 03:00 PM
izmir41500's Avatar
G35driver Addict
wheels don't matter, it's the tire. i run 35 on stock 19"s
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
joedaddy1
Jul 28, 2015 02:58 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
realtalk21
Jul 20, 2015 09:07 AM
