Stripped Nuts
Old Apr 2, 2007 | 12:33 AM
liukai's Avatar
Stripped Nuts
First i'd like to dedicate this to these guys who save us from stripped nuts. . .now, does anyone know how to get the damn nut off of it? its like fused to it!
Old Apr 2, 2007 | 01:45 AM
ttrank's Avatar
Grocery getter
Spray it with WD40 and let it sit for a while and try again.
Old Apr 2, 2007 | 01:47 AM
idwin's Avatar
hold it w/ pliers, take another set of pliers on the nut and twist it the opp direction!
Old Apr 2, 2007 | 01:49 AM
DaveB's Avatar
Been there, done that.
1) Flat blade screwdriver
2) hammer
3) hammer from the inside out.
Old Apr 2, 2007 | 02:01 AM
G35Dreamz's Avatar
Where did you buy it? It could've save me a few times when i stripped several nuts. I got the gator grip one but it didn't help much.
Old Apr 2, 2007 | 02:05 AM
liukai's Avatar
thanks for the advice guys, wd40 is a definite. . .twisting with two pliers is tough to get a girp with but it woudl be nice to thread it on a bolt and use that! hammering it out seems the way i'm gonna go. . .i got a whole set from Sears. autozone didn't have it surprisingly.
Old Apr 2, 2007 | 02:30 AM
ttrank's Avatar
Grocery getter
Good luck!
Old Apr 2, 2007 | 04:21 AM
bobshuai's Avatar
try use the punch & chisel, chisel the nut around the opposite site. It might work sometimes.
Old Apr 2, 2007 | 07:53 AM
k_hojnacki's Avatar
just thread it partiially on a bolt, then knock it off
Old Apr 2, 2007 | 09:20 AM
hokiesean24's Avatar
lube and keep beating it til you get it off...
Old Apr 2, 2007 | 12:55 PM
sydg35's Avatar
find a matching shorter bolt that fits the nut at home depot. thread it down to the base. use a wrench on each end and turn them like you were tighten the nut down. i think it should come off, it looks like the tool is designed to grip the nut in the same direction you would turn to loosen it.
Old Apr 2, 2007 | 01:05 PM
Hi-TechG35's Avatar
Heat em up and crack em.
Old Apr 2, 2007 | 01:09 PM
gary c's Avatar
Best bet.......
If it was mine I'd put it in a vice and carefully tap around the edges until it
came loose. Then I go to Sears and buy the correct socket that fits my
lugs....at least a 1/2"!
NyCrAzY
Oct 1, 2015 09:19 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
