thoughts a/b eibach
Old Dec 21, 2003 | 07:00 PM
jaxxx's Avatar
thoughts a/b eibach
What's your thoughts a/b the eibach pro kit? Satisfied? Low or ntolow enough? Thougths pls.
Old Dec 25, 2003 | 04:33 AM
ripass's Avatar
Re: thoughts a/b eibach
cant be beat for the price...not too noticable but will bottom out if your not careful. need to shop for shocks and swaybars.
Old Dec 25, 2003 | 12:27 PM
Gsedan35's Avatar
Bottoming out isn't going to be solved by shocks. Problem is your lower with part of the suspension travel on springs that are actually softer than stock, even their final rates aren't much firmer than stock, can even be softer than stock. Take a look, at the specs below and compair to the stock springs.
Eibach Pro-Kits initial and final spring rates in LBS
G35s 259/334 front 359/413 rear
G35c 229/337 front 274/463 rear
Stock spring rates
F/R in lb/in
350Z and G35 coupe: 347/419
G35 sedan with sport: 357/407
"i, for one, am not a fan of glory hounds."
Dang straight, it's all about the glory of helping. Who have you helped today?
Old Dec 25, 2003 | 03:43 PM
jaxxx's Avatar
I'm basically just getting some springs for the looks but not really for performance. So from my point of view... It's worth getting it for the looks and closing the gap?
Old Dec 25, 2003 | 05:42 PM
ripass's Avatar
IN GENERAL, lowering a car improves handling. shocks will improve rebound and dampening which will improve traction and more importantly...confidence at higher speeds. Shocks will also aid in bottoming out. have u ever been on a pogo stick.....same concept especially over a slow bump......will keep bouncing and bouncing and bouncing right into your undercarriage. but i guess some people like that.
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dseet
Oct 11, 2015 12:40 AM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
Jay123
Sep 28, 2015 08:42 PM
wow600rr
Sep 28, 2015 11:50 AM
