larger tires on stock rims
Old Apr 13, 2007 | 11:45 PM
sublim3's Avatar
Originally Posted by AthensBlueG
And if you want the best possible prices for Toyo tires, I'd recommend TireDeals4Less (site sponsor). I couldn't believe how inexpensive they were compared to other vendors.
+1
I just purchased a set of Toyo's from them. Cheapest around + great customer service + fast shipping.
Old Apr 14, 2007 | 12:23 AM
DarkG's Avatar
I would suggest keeping 245's in the rear.. 255s don't make enough difference.... trust me.. just get a good tire and keep 245s in the rear... I have the OEM 19's.. and thats what I'm gonna keep doing till I get dif rims!
Old Apr 14, 2007 | 01:16 AM
visualfusion's Avatar
how much of a difference would the aspect ratio make? I know it changes the wheel diameter but would it make a difference in how long the tires last? ...
245/xx/19F and 255/xx/19R -- 35 and 45 aspect ratio
getting toyo T1R's from tires deals 4 less... is that a good place to buy? good experiences there everyone?
Old Apr 14, 2007 | 03:35 PM
joe603's Avatar
I think I'm going with 245/35 for the front and 275/35 for the rear. There are a few people who swear by this setup. Any other size combo, other than stock, would risk the VDC freaking out.
I just don't like the look of the stock tire size...but love the stock 19's...I wish they made the rear an inch wider!
Old Apr 14, 2007 | 04:53 PM
mondo's Avatar
Have this setup for a few months now.... toyos 245/275 x 35. luv it.
Quieter than stock tires, more grip, very close to correct speed... throw some 10mm spacers all around to make more flush with fender and it's as good as your going to get with stock rims.
Old Apr 14, 2007 | 05:31 PM
joe603's Avatar
Any particular type of spacer? Do you have a good website for the part?
Thanks!!
Old Apr 18, 2007 | 02:36 PM
joe603's Avatar
Decided against the spacers...I want to see how the 275's look on the rear first...should get 'em put on tomorrow.
Old Apr 18, 2007 | 11:11 PM
mondo's Avatar
Just in case you change your mind...
www.evasivemotorsports.com
This is the only place I know that gets Kics spacers. The benefit is they are simply bolt on... they come with studs already on the spacer so you don't need to lenghten the stock studs.
He gets limited quantities of 10mm size. You might be able to 15mm on rear but it's very close so I didn't chance it.
Old Apr 19, 2007 | 04:48 PM
MadMatt1144's Avatar
Would it be straight to put on 245/35/19 and 255/35/19 on the OEM 19's? anyone I've heard of with this setup usually goes with a 255/40/19 in the rear.
Old Apr 19, 2007 | 06:33 PM
mak's Avatar
mak
i have an 05 n i upgrade my tires to 245-35F n 275-35R Nitto Neo-Gen n i put like 15,000 on them already n they r still riden good! handles real good n also good tracton! they look real good on da rims! makes them stand out alot more!
Old Apr 20, 2007 | 11:43 AM
joe603's Avatar
That's the general consensus from the board. I put mine on next week...I'll take some pics for the group.
Old Apr 25, 2007 | 11:16 AM
joe603's Avatar
Finally got 'em
Had the tires put on the car yesterday, and they look much better than stock! Thanks to all who helped!!
Old May 9, 2007 | 03:22 AM
PhxBlue's Avatar
Polyester Pileup FTW!
Can you take pics?
Old May 9, 2007 | 03:40 AM
RichardxG35's Avatar
i have nitto invo tires on my 19" 235/35/19 front 255/35/19 rear this is the best setup i recommend it to everyone.. and 19" tires don't come cheap! the rear is 19x8.5... going 275 is not call for.. if you go 245/35/19 front and 255/40/19 rear that is off the mark.. but if you do GL getting a match set...
Old May 29, 2008 | 02:18 AM
  #30
abwrestling33's Avatar
How is that setup(245/35 front and 255/40 rear) "off the mark"? Redlude97 recommended that exact setup in previous threads and that was the setup i was considering going with. Is there a reason why I shouldn't? I just want to get the falken tires but they don't make the OEM 19" size(225/40) so thats why I am considering different sized tires from the OEM sizes. What would be the option that is close to OEM that falken makes?
