larger tires on stock rims
Old Apr 12, 2007 | 12:14 PM
joe603's Avatar
Hey guys, my 05 is due for new rubber. I'd like to put on wider tires on my stock 19s. Has anyone done this before? Any pics of the results?
The stock sizes are:
225/40-19 front
245/40-19 rear
I'd like to put on
245/35-19 front
275/35-19 rear
What do you guys think? I don't want to hurt performance, but I don't like the skinny look of the stock setup...
Old Apr 12, 2007 | 12:16 PM
g35rcr's Avatar
search its been done more times paris hilton
Old Apr 12, 2007 | 12:28 PM
joe603's Avatar
I did...but I couldn't find a good thread. Can you point me in the right direction? (I'm new to this board )
Old Apr 12, 2007 | 12:36 PM
JOKER's Avatar
CLUB MODERATOR
I think that is too much.
You could prolly get away with 245 for the front and 255 for the rear.
But what you acre proposing is too much.
Old Apr 12, 2007 | 12:50 PM
DarkG's Avatar
you can fit 255s in the rear... I think thats as big as you can go on OEM 19's
Old Apr 12, 2007 | 12:54 PM
Finiti's Avatar
Did you look in the wheel & tire section?
https://g35driver.com/forums/showthr...ighlight=stock
Old Apr 12, 2007 | 01:26 PM
BadBoy06's Avatar
I've heard of 265's just not sure if that was on the 19's
Old Apr 12, 2007 | 01:46 PM
joe603's Avatar
Thanks for all the good replies! I've been on the fence with this one for a while now. I asked a tire tech the largest tire that could fit on the rear 8.5" rim...according to him, 275/35 would work. I'm just not sure if it's a good idea. (don't want to hurt handling, I want more grip!)
This is a cool website that allows you to play around with different sizes. Thought I'd share to the group....
http://www.bigcustomwheels.com/info_specs.jsp
Old Apr 12, 2007 | 02:40 PM
JOKER's Avatar
CLUB MODERATOR
^this site suggests 255 for the widest tire for the rear.
Old Apr 12, 2007 | 09:42 PM
xjonmo's Avatar
what if you just went with stock sizes? how would that affect performance
Old Apr 12, 2007 | 10:36 PM
bocatrip's Avatar
These Coupes already have issues with the rear tires wearing prematurely on the middle treads with the stock tires. I would be careful going any wider as you will be changing the footprint of the tread and possibly start making it concave causing the middle tread wear. Don't necessarily believe the specs for your rim width. It's always safer to go with a rim width at the top of the recommended sizes. Too wide a tire on too narrow a rim will cause the tread to bulge outwards.
Old Apr 13, 2007 | 10:08 AM
joe603's Avatar
This thread is a wealth of information on wider tires on stock rims!!
https://g35driver.com/forums/wheels-tires/73638-275-s-oem-19-s.html
Old Apr 13, 2007 | 10:17 AM
AthensBlueG's Avatar
Brian
I just installed 245/35/19 Front and 255/40/19 rear. It looks great, and I can launch better with less slippage. Anything wider in the rear is not a good idea.
This tire size calculator rules all. Check it out...you'll see that 255/40/19 rear is the closest to stock height that you can get.
http://www.rims-n-tires.com/rt_specs.jsp
And if you want the best possible prices for Toyo tires, I'd recommend TireDeals4Less (site sponsor). I couldn't believe how inexpensive they were compared to other vendors.
Old Apr 13, 2007 | 11:33 AM
joe603's Avatar
How do the Toyo's compare to Goodyear Eagle F1's?
