RE- Offseting wheels
Old Apr 12, 2007 | 08:14 PM
Tunerz_Store's Avatar
Is it possible to have the offset on wheels changed? Say you have a 30 offset wheel and you wanted to have it machined to a 38 offset.
Old Apr 12, 2007 | 08:20 PM
redlude97's Avatar
You can on some wheels, but it will likely effect the integrity of the wheel to the point it becomes unsafe, especially 8mm
Old Apr 12, 2007 | 08:23 PM
GEE35FX's Avatar
^^^+1 not advisable to machine the wheels as he says.
Andy2434's Avatar
http://www.tirerack.com/wheels/tech/...jsp?techid=101
If what you mentioned were offered, I would have to believe that it would come at a very high cost. Thus, making it terribly impractical.
Old Apr 12, 2007 | 08:27 PM
BadBoy06's Avatar
just a bad idea..no matter what the shop may say
Old Apr 12, 2007 | 08:42 PM
From the little bit of research I have done, most say 3mm is the most any wheel machine shop will take off without sacrificing any wheel integrity. Which is quite a bit in theory. Take for example, the z track wheel of a 8.5" width with 33mm in the rear that I'm running. If it were machined 3mm's to make it 36mm, a tire size of 255/40 could be used without any rubbing, instead of the 235/45 I used now now and could probably run a 245/40, but take the risk of rubbing.
Old Apr 12, 2007 | 08:53 PM
redlude97's Avatar
I'm not sure how moving the wheel 3mm in will give you 20mm of tire clearance
Old Apr 12, 2007 | 09:05 PM
You can run a 245/40 as it stands without any tire rubbing with about 2-3mm of clearance with some negative camber. Now if you move the wheel in another 3mm's, you should be able to to get a 255/40 under there. 255 is 10mm wider obviously... 5mm stick out further and 5mm closer to the suspension. A slight fender roll maybe in order, maybe not. Just throwing some options out there.
Old Apr 12, 2007 | 09:08 PM
redlude97's Avatar
If your fenders aren't rolled yet, that is definetly the first and safest step to clear larger tires. A good fender roll can get you 7-8mm of clearance by itself, and not machining of the wheels would be necessary
obender66
18 Inch
Mar 13, 2016 12:20 PM
imRACERX
19 Inch
Sep 10, 2015 08:53 AM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
