Tire Wear Pattern for RWD Cars
I've been searching around for this and haven't had luck finding a solid answer. I know with FWD cars that the front tires always wear the quickest. With RWD cars being more balanced and the traction and steering tasks being split between the front and rear, is there any bias on wear for RWD cars?
I'm going to put my summer wheels/tires back on and noticed one set has slightly more wear. I wanted to put that set in the position that wears the slowest. Thanks for the help!
Damon
Damon
Of course the drive tires will wear faster. Unfortunately, with the stock G35 rims, the middle rear treads wear prematurely rather than evenly across. With the fronts, the inside feathering is another issue. The sedans can be rotated but don't have the front issues anyway. The 08 G37 will give everyone an option with the 18's being non staggered for rotations.
Tire pressure is really important with tire wear as well, always check your tires (and oil, coolant, power steering fluid, brake fluid) at least once a month or more if you drive a lot.
Thanks for the response Bocatrip. I found another article that confirmed what you said and what I was thinking that the rear wheels would wear faster. Anyway, the summer wheels are back on and look great.
The fronts need constant alignments to reduce feathering and the rear rims are too small for the tires wearing the centres. I run less pressure there but it doesn't help much at all.
Originally Posted by RBull
Exactly right. You're one of the few on here that post both of these issues. I have them too.
rezendvous420
May 31, 2020 01:26 PM
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
