Can you take the face off a 2-pc wheel?
Old Apr 17, 2007 | 02:33 PM
ttrank's Avatar
Grocery getter
I am about to get a set of Volk GT-C's and want to have the face powder coated. The shop is going to charge me way more if they have to mask off the lip and since they are 2-pc with the bolts I was wondering if I can just take them apart?
Has anyone done it?
Old Apr 17, 2007 | 02:39 PM
redlude97's Avatar
It can be done on the GT-C's as they are bolted 2 piece wheels. Not sure on the torque specs though so you may want to find out so you can reassemble them correctly
Hi-TechG35's Avatar
If you look at the back of the rim and it is not welded you should be able to. Me personally Ttrank, wouldn't recomend doing it yourself because some wheels have beeds that you may crack when removing the face from the barrell. Just have them mask off the wheel and powdercoat. That way you wont have to worry about damaging the structural integrity and dependability of the wheel. Also shop around for places that will powdercoat the wheel for you.
Old Apr 17, 2007 | 02:52 PM
ttrank's Avatar
Grocery getter
Thanks guys.
This place only does powder coating and will do them for $60 each but he said that was for the whole rim. I am not sure what has to be done to mask off the lip. Maybe I can prep the rims and bring them in. That green painters tape is not too expensive.
Old Apr 17, 2007 | 03:34 PM
redlude97's Avatar
you need heat resistant tape, which the green painter's tape isn't
Old Apr 17, 2007 | 04:54 PM
ttrank's Avatar
Grocery getter
Do you know of any tape that is good to 400 degrees? I guess the shop would have it but I was trying to save some money and prep them myself.
Old Apr 17, 2007 | 05:44 PM
redlude97's Avatar
not anything you can buy at a normal store. Ask your PC shop to sell you a few rolls, but IMO removing the face is the best idea
Old Apr 17, 2007 | 06:05 PM
burns420's Avatar
if you take them apart it is near impossible to get it right put back together. youll almost always have some wobbles and bearing problems later on
Old Apr 18, 2007 | 11:56 PM
ttrank's Avatar
Grocery getter
I have decided to sell them and get different wheels later.
Thanks everyone for your help.
Old Apr 19, 2007 | 01:14 AM
rijowysock's Avatar
if u take them apart its easy, takes 15 mins a wheel
reassembly the center is pre balanced so u cant put em back wrong.. u just line up the valve stem hole.
tq is 25ft/lb per bolt.
id reconsider pc'ing them
Old Apr 19, 2007 | 11:46 AM
ttrank's Avatar
Grocery getter
Thank you.
It looks like they have blue thread locker on them so I assume I should use the same to put them back together.
Old Apr 19, 2007 | 01:32 PM
rijowysock's Avatar
thread locker should stay on the bolts when u take them out..
like i said the whole process is VERY easy.. easier w/ volks than any other wheel because the volks dont have 2 pieces of hoop.. meaning you dont have to silicone between the hoops after you remove..
you can even take them apart w/ the tires on and air in the tires.. that what i did because the stem it attatched to the hoop and u just remove the face out the front.
any more assistance lemme know, ive done this on 2 sets of volks in past and a set of race CCW
:-D
Old Apr 19, 2007 | 02:53 PM
panda007's Avatar
damn. that's wide.
wouldn't taking out the center face lose the balance of the wheel itself? or i guess the torquing of the bolts will handle that... as long as the bolts are torqued at the same spec.
Old Apr 19, 2007 | 03:14 PM
617G's Avatar
CFW (Carbon Fiber Whore)
fwiw, down_shift took his GT-C's apart and got them PC'ed. I'm doing the same with my Maidos. It's not hard.
Old Apr 20, 2007 | 12:15 PM
ttrank's Avatar
Grocery getter
Awesome. If I decide to keep these I will have the faces done in a different color.
Thanks!
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
