Who have 18" wheel?
Old Apr 24, 2007 | 10:24 AM
bbboltz's Avatar
Who have 18" wheel?
What size tire for 18x8.5 on a 2003 sedan? 235/40/18 or 255/40/18
also. go staggered(8.5f and 9.5r) or one size 8.5?
If to go staggered what size tire again?
(did search and didnt had much luck)
Old Apr 24, 2007 | 11:54 AM
g35sedan5at's Avatar
a 245/40/18 should be ur best bet. as for staggered, thats personal preference.
Old Apr 24, 2007 | 12:04 PM
Texasscout's Avatar
I have 245 45 18 Goodboot RS-A all round. I like em.
Old Apr 24, 2007 | 01:02 PM
dahkyne's Avatar
IB4TM
To answer your question - I'm running 18x8.5 all around with staggered tire sizes - but it depends on your offsets; mine are ET40 front + ET45 rear
For tires, I'm running 225/45/18 Front + 245/45/18 Rear - same as the 18" OEM tire sizes for coupes
Depending on what you want - I would recommend:
For ability of rotation - 235/45/18 all around << stock size for sedan 18s
Staggered - 225 or 235 /45/18 Front + 245/45/18 or 255/40/18 Rear
I don't know if you want to go with stock tire sizes or want to go with a lower profile... I would stay with close to stock sizes to prevent the VDC from going nuts.
Old Apr 24, 2007 | 08:39 PM
bbboltz's Avatar
ok imma get 18x8.5 +35 & 18x9.5 +35
so 255/40/18 & 265/35/18 looks good?
Old Apr 24, 2007 | 09:58 PM
(>")> G35's Avatar
I'd go:
245/45/18 front +35
275/40/18 rear +45
+35 on the 9.5" rear is going to stick out of the fender by 10mm.
Old Apr 24, 2007 | 10:59 PM
bbboltz's Avatar
Originally Posted by (>")> G35
I'd go:
245/45/18 front +35
275/40/18 rear +45
whats ur offset?
Old Apr 24, 2007 | 11:03 PM
Tunerz_Store's Avatar
with a 9.5" wheel in the rear, you need @ least a 42 or higher. 35 offset on the front is fine with 8.5" wheel.
Old Apr 24, 2007 | 11:26 PM
(>")> G35's Avatar
whats ur offset?
Front is a +38 and rear is a +45, it's perfectly flush in the rear.
Old Apr 24, 2007 | 11:35 PM
bbboltz's Avatar
so am i better off going both 8.5?
Old Apr 24, 2007 | 11:37 PM
(>")> G35's Avatar
What wheels are you looking to get? There might be more sizes.
Old Apr 25, 2007 | 01:56 AM
STOOF's Avatar
im running 18s with +38mm offset all around and 245/45/18 tires all around...no rubbing issues whatsoever and there perfectly flush with the fender
Old Apr 25, 2007 | 03:32 AM
bbboltz's Avatar
im getting sportmax 006
http://www.sportmaxwheel.com/sportmax_006.shtml
Whats the width on your rim??
Old Apr 25, 2007 | 02:43 PM
bbboltz's Avatar
anymore input???
go for 8.5 all around or ?
Old Apr 26, 2007 | 01:07 AM
bbboltz's Avatar
picked up 8.5 all around thanks for all the help guys
