Tire pressure for aftermarket tires....
Old Apr 25, 2007 | 08:10 PM
DrkBLuG35Sdn's Avatar
I have toyo T1R proxies and I want to kno what pressure to have them at is it the same as the stock 17's that came on my car? or where can I find what they are supposed to be at?
Old Apr 25, 2007 | 08:20 PM
ttrank's Avatar
Grocery getter
I run 35-38 in mine.
Old Apr 25, 2007 | 08:47 PM
DieselX's Avatar
Yea I actually don't know what to run in mine. 20" with falken 452's... 245/35 in the front and 275/30 in the rear. Suggestions?
Old Apr 25, 2007 | 09:04 PM
bkd's Avatar
bkd
Check the drivers door jamb for recomended pressures. Usually 32-33psi works well. In general, higher pressures firm up the sidewalls resulting in more precise cornering, but at the expense of ride comfort. If you really go too high you can cause the middle of the tread to bow out and cause premature wear and reduce the contact patch with the road in some conditions. Going lower will increase ride comfort, but as the sidewalls start to bulge out you will increase wear on the tire significantly as the sidewall will flex and heat up more on each revolution. Too low a tire pressure can also make it possible to rip the tire off the bead if you catch it on a curb or bad pothole. Probably anything that makes the TPMS happy up to around 40psi is fine for everyday use, as long as both wheels on the same 'axle' are running the same pressures and you are happy with how the car drives and handles. Different brands of tires can have dramatically different sidewall stiffness and you may have to play with pressures to get the same feel as before. Experiment to see what you like and what works best for you.
Old Apr 25, 2007 | 09:16 PM
jimmyc13's Avatar
It will help a LOT if you tell us what tire size you're running. If you're running 245/35/19's, you definitely shouldn't use the door jamb technique mentioned above ....as those are for the OEM setup. Ttranks recommendations are valid if you're running a low profile tire. I run my 245/40/19's at 37 psi.
Old Apr 25, 2007 | 09:25 PM
ckrug03's Avatar
If your running a larger rim and tire combo i would shoot for 35 to 40 psi. On my 19's with a 35 series tire i kept a steady 38 to 40 psi.
cole
Old Apr 25, 2007 | 11:12 PM
245/40/19 Front and 275/35/19 Rear so high 30's for both front and back?
Old Apr 26, 2007 | 01:25 PM
ttrank's Avatar
Grocery getter
My friends at Discount tire like ~35 in those (I have the same sizes).
Old Apr 26, 2007 | 01:50 PM
g35rcr's Avatar
they have a air pressure list at discount tire...if you upsize you want to drop 1lb for each 1-2 size upgrades...i run 32 in all mine...
Old Apr 26, 2007 | 07:40 PM
SilverII's Avatar
35.
jsimonk
Dec 22, 2023 03:49 PM
bTanz
Oct 15, 2015 02:31 PM
derres
Aug 28, 2015 03:27 PM
joedaddy1
Jul 28, 2015 02:58 PM
