putting TPMS in my new wheels....what to use as stems for oem?
Old May 10, 2007 | 05:23 PM
rijowysock's Avatar
have oem 19" wheels w/ TPMS.. going to have the shop put the tpms on the new wheels.. (the tpms im pretty sure is the actual stem+lil box) so then what can i use as stems on my oem 19's?
would a regular pull thru rubber stem work on them? or am i going to need to buy something special like volk aluminum stems?
thank you in advance. need an answer asap.
riley
Old May 10, 2007 | 05:27 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
go to a tire shop and ask them for 4 black rubber valve stems.
-GP-
Old May 10, 2007 | 05:32 PM
ttrank's Avatar
Grocery getter
That is what I used on my first two sets of wheels. Had to get brackets to mount them in my Volks.
Old May 10, 2007 | 05:40 PM
rijowysock's Avatar
ok so the black rubber ones will work as temporary's on the oem 19's?
thats all i was wondering because i know on some volks ive had in past they didnt work cause the hole was too small... so i wanted to make sure before i took my new wheels there to be mounted/balanced.
so as of now im just gonna put temporary rubber stems in the oem 19's incase i get a flat/etc and then put the tpms banded inside the new wheels..
awesome, thank you guys VERY much for the prompt response.. i just wanted to make sure while i still had time to overnight some rays stems if that was the only option
riley
TheKnite
Aug 14, 2015 07:59 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
Jadenkid22
Jul 14, 2015 12:33 AM
