Coupes using 245/40ZR18 front and 275/40ZR18 rear
Old Jan 2, 2004 | 10:08 AM
Micah's Avatar
Re: Coupes using 245/40ZR18 front and 275/40ZR18 r
275 is way too wide for an 8" rim. You need aftermarket wheels for those tire sizes. Might as well get lighter wheels, too.
Old Jan 2, 2004 | 10:15 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: Coupes using 245/40ZR18 front and 275/40ZR18 rear
Most people running the 245/275 are running 8.5/9.5.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Old Jan 2, 2004 | 07:12 PM
lowrider's Avatar
You've asked the same question at freshalloy. See my answer there. It's risky at best. Don't do it.
Lou
Old Jan 3, 2004 | 08:59 AM
lowrider's Avatar
You know, Oh forget it, your not worth the time.
Old Jan 3, 2004 | 02:05 PM
lowrider's Avatar
You got my PM at my350Z I presume?
Lou
Old Jan 5, 2004 | 09:26 PM
Ted's Avatar
Ted
Hi, Finally got through to the forum. I sent you a detailed private note here as I couldnt accesss you on the forum.
The setup works fine and looks great.
Ted
Old Jan 5, 2004 | 09:31 PM
Ted's Avatar
Ted
One more point, the rears measure slightly wider than the front, although they are both referred to as 8". The are also stamped front and rear, same offset but about .5" wider in the rear.
Ted
Old Jan 5, 2004 | 10:30 PM
lowrider's Avatar
I had my wheels off my car, before I sold them. Both measured the same (8"). I had heard this also, and I checked just to be sure.
Lou
Old Jan 6, 2004 | 12:46 AM
Buddha's Avatar
there was a picture posted a while ago with this setup. I would be interested in this setup as well.
04 G35C 6mt/aero kit/nav/premium
