rear brembo clearance question
May 23, 2007 | 05:07 PM
Would i be able to fit a SL (super low) disk for the rear of a g35 coupe w/ rear brembo? or would i have to go with a NR (normal) disk?
Reply 0
May 23, 2007 | 05:20 PM
Quote: Would i be able to fit a SL (super low) disk for the rear of a g35 coupe w/ rear brembo? or would i have to go with a NR (normal) disk?
You need to be a little more specific,what are you trying to do.
Reply 0
May 25, 2007 | 07:57 PM
just trying to see if i can fit a 11" wide offset +12 with a super low disk (face of the wheel) vs a normal or hyper disk (hyper disk clears bbk).
Reply 0
May 25, 2007 | 09:09 PM
depends on the wheel, which one are you looking at?
Reply 0
