Need tire help and advice ASAP
Old May 21, 2007 | 05:02 PM
oooooooooooooq's Avatar
I recently bought O.Z. Chrono HT wheels size 17x8 with +40mm offset (i dont understand sizes and stuff so if you can help me with that to thanks) and i got pilot sports 235/50/zr17 and it doest have a nice look ( they look like truck tires) what sizes fit, and what would look the best, and should i keep wiht the ps2's or get another tire like kuhmos or bridgestones,
PLEASE HELP
Old May 22, 2007 | 08:41 AM
ron4row2's Avatar
I recently purchased General Exclaim UHP tires. They are great tires and relatively inexpensive. They also look great. I'd check them out.
Old May 22, 2007 | 10:24 AM
what about sizes, and stuff, and do you think anyone would buy my ps2s
Old May 22, 2007 | 10:28 AM
Hi-TechG35's Avatar
The first number usually indicates the width of the tire and the second number is the height and the last is the size of the tire.
Old May 22, 2007 | 10:30 AM
i know that (sorta) but if i have 235/50, would 235/35 just make it lower profile, because some other people like change the width to
Old May 23, 2007 | 02:24 PM
04NismoV35's Avatar
The reason it might look like a truck tire is that you only have 17's. I have the same tire size, and I think they look ok on the stock wheels, but your 17x8 probably doesn't help. DO NOT change the profile unless you are getting bigger wheels. Bigger wheels will help the look A LOT! BTW 235/35/17 will make the speedo run a 10.8% faster than actual. When your speedo is showing 60mph you'll be actually going 53.5mph and every 10k mi. you'll be adding close to 1100 extra miles to the odometer. Use this calculator to help you.
Miata Tire Calc
BTW I have a set of 18" coupe wheels I need to unload if your interested.
Old May 23, 2007 | 03:15 PM
g35rcr's Avatar
I finally put my toyo t1r's today on...compared to the kdw no noise what so ever they hook up nicely...great tire
Old May 25, 2007 | 11:58 PM
mgmoreau's Avatar
+1 on T1R's
Jussumman
Dec 22, 2015 10:23 AM
miata007
Aug 17, 2015 04:36 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
nascarbuff17
Jul 16, 2015 10:23 AM
