The WIDEST tire I can fit on my '03 Coupe?
Old May 28, 2007 | 07:38 PM
cor72vette's Avatar
IMO yes, it will look retarded, get some bigger tires, 255/40/18, 285/40/18
Thanks for the info and your help. I'm not sure how you calculate the size fittings, but you're sure I won't have a rubbing problem using 255/40/18 and 285/40/18 sizes? Thanks again!
Old May 28, 2007 | 07:42 PM
cor72vette's Avatar
Also, is it possible to use my current rears 245/45/18 on the front instead of the 255/40/18 you suggest? The tires are nearly new, it would be nice to reuse them... I'd still buy the 285/40/18's you recommend for the rears. TIA!
Old May 29, 2007 | 01:22 AM
lowrider's Avatar
You'll kill the stagger if you did that. The recommended sizes for your new wheels are 245/40/18 and 275/40/18 front and rear. However, the 255/40, 285/40 combo will work.
Lou
Old May 29, 2007 | 01:27 AM
RichardxG35's Avatar
245/40/18 F and 275/40/18 R these size are easy to get.
Old May 29, 2007 | 07:56 AM
BRN G35's Avatar
i have a 05 G35 coupe. i have installed 245/35/19'" front and rear 285/30/19"
no problems at all. you could go even up to 305 rear but your car will need rolling first.
AB
Old May 29, 2007 | 09:06 PM
cor72vette's Avatar
I ordered G-force 255/40/18 for the fronts and 285/40/18 for the rears. It should look sweet, I just hope they fit!!!
Old Dec 1, 2009 | 01:51 AM
lecontainer2007's Avatar
is this going to fit on my 03 g35 coupe 255/30/20 fronts and 285/30/20 rears?
Old Oct 29, 2018 | 01:45 AM
Pro_physic's Avatar
6mt Rev up
What is the widest tires I can fit on a 9.5 rim front and 10.5 rear...?
To the OP, 255/40/18 and 285/40/18 is the widest tire you can fit on your wheels
I currently have 245 front tire on a 9.5 rim and 275 tire on a 10.5 rear rim..what's the widest tires I can go for my car without spacers?
Old Oct 29, 2018 | 03:39 AM
ScraggleRock's Avatar
Should have asked 10 yrs ago
Old Oct 29, 2018 | 10:19 AM
Urbanengineer's Avatar
Ohhhh snap look who's back!
Old May 2, 2020 | 11:37 PM
MurdaG's Avatar
It's got 2 doors 😂
😂😂😂 I'm ☠
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
LoSt180
Jul 15, 2015 08:31 AM
