245/35/19 front 255/40/19 rear possible?
Old May 28, 2007 | 04:11 PM
Snapple37's Avatar
Hello,
I am in a dilemma. I have to replace the OEM tires soon on a '06 coupe 6MT. OEM tires are out of the question because I can't afford (or don't want to pay) $1000 set of 140 tread wear tires.
I've done some reading and the consensus seems to be 245/35 front and 265/35 or 275/35 for the rear when replacing tires on stock 19" wheels.
Well, I can't find a matching set... the best I've come up with is
General Exclaim or Kumho SPT 245/35 fronts (never heard of general, but has the best rating on tirerack) and Kumho SPT 255/40 rears.
Is 10mm staggering enough to keep the VDC happy? I know stock front/rear stagger is 20mm, and that my speedo will be off by about 1.2%. However, if 10mm stagger won't ruin the car's balance, then I could save alot of money with these tires.
P.S. I''ve had good experience with Kumho tires before, and wider track should help anyway.
Old May 28, 2007 | 05:07 PM
redlude97's Avatar
that setup will be fine
Th611
Oct 27, 2015 03:48 PM
st33zygill
Jul 29, 2015 10:05 PM
Popes
Jul 29, 2015 05:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
