Anybody try 245/40R/19 tires in the front?
Old May 29, 2007 | 11:49 AM
Fourlix's Avatar
After 21,000 miles on my original Bridgestones, I need tires. The Michelin Pilot Sport PS-2s get the best reviews, but the fronts are $321 for the 225/40R/19s and the back 245/40R/19s are only $285. Tire Rack prices.
Why not just go with the 245s all the way around, and be able to rotate? Are there any problems doing this?
I need a fast answer.....thanks, guys
Old May 29, 2007 | 12:21 PM
MeetJoeAsian's Avatar
hmmm...I'm Sure someone has...
Old May 29, 2007 | 01:48 PM
lowrider's Avatar
There are many threads about maintaing the stagger that's designed into the coupe. If you don't know what that means, do a search and you'll find it. BTW, the new G37 will not have the stagger issue.
In a nutshell, the fronts are about 1" less in diameter than the rears, and that size differential must be maintained. 225/40/19 is a rare size, and thus expensive. You can run a 245/35/19 in front and maintain the stagger. The 245/35, 245/40 combo would reduce the understeer and make your vehicle more neutral handling. This may or my not be good for you.
Lou
Old May 29, 2007 | 07:28 PM
^^^what hE said...
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
wuppiedog
Aug 7, 2015 11:16 AM
bjo16
Aug 4, 2015 09:52 AM
BlackGee35
Jul 31, 2015 11:04 AM
