Anyone with nismo wheels...
Old Jan 8, 2004 | 10:00 PM
ericinmia's Avatar
Anyone with nismo or Ray's racing wheels that are the five spoke design could you post a pic of them!
<a href="http://www.performancenissanparts.com/catalog/product_info.php?cPath=153_178&products_id=227&osC sid=ba7b65cfd3d25b8defb323f3e60a3be4">I saw an advertisement for this on my350z.com</a>
Anyone know of a better, or cheaper wheel... i have about 3g's maz to spend.
Thanks
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Jan 9, 2004 | 10:21 AM
JspecG35's Avatar
Re: Anyone with nismo wheels...
RugRatCoupe has silver Nismo LM GT4's
https://g35driver.com/rides/spec/pix...1068009692.jpg
Old Jan 9, 2004 | 01:24 PM
lowrider's Avatar
Yes
Go here:
http://my350z.com/forum/showthread.p...threadid=55634
You'll see my car. I can get them for $1,799. plus $60. shipping. If interested PM me/
Lou
Old Jan 10, 2004 | 08:42 AM
Tfasano's Avatar
I just noticed the add above says they are for non VDC cars only. Anybody know why?
Luv My G
Old Jan 10, 2004 | 10:25 AM
ericinmia's Avatar
it is nismo's little insurance, they don't want to be liable...
vdc is fine. but nismo will only guarantee that vdc is fine if you buy their suspension package, and sways, and wheels all together....
-Eric
Old Jan 10, 2004 | 10:31 AM
lowrider's Avatar
IMO, it's Nismos way of selling suspension pieces. If you read the fine print it says it's OK if you put on Nismo springs and sway bars. This just doesn't make sense. I believe, that as of now, the warning has been withdrawn. Anyway, I have had no problem with my VDC. If you keep the by ODs the same as stock with the 245/40 and 275/40/18 tires, all will be fine.
Also, if the warning really were true, it would apply to all aftermarket wheels, and we all know that just isn't true.
Lou
Old Jan 11, 2004 | 10:57 PM
ericinmia's Avatar
why if i have 18's now, and a 245/45/18 tire (rear) should i go with the 275/40/18 tire (rear) with the new nismo wheels? sorry for my ignorance on this topic.
Wouldn't that be decreasing the tire wall height? I am not going to be dropping the car, so would staying with a 45 height be better?
Thanks a bunch!
-Eric
Old Jan 11, 2004 | 11:26 PM
1nate7's Avatar
Sidewall height is a percentage not a fixed measurement. 45% of 245 is almost identical to 40% of 275, therefore keeping overall diameter the same. Also for the same reason, the fronts would be 245/40/18 instead of 225/45/18. That is optimal for 8.5"/9.5" wide rims BTW, although some people are running these sizes on the stock rims without any reported problems.
DG/G 6MT coupe, Borla exhaust, Stillen intake, Z aluminum pedals, clear corners
Old Jan 12, 2004 | 12:16 AM
ericinmia's Avatar
awsome, thanks for the info!
-Eric
Old Jan 12, 2004 | 07:40 AM
lowrider's Avatar
Yes, some people are running those tires on their stock rims at their own risk. It's not recommended by any of the tire manufacturers. The recommended rim width for 275/40s is 9.5", the stock rim width is 8". Just wanted to set the record straight.
However, running 245/40s on the stock rims in front is fine.
Lou
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
