Nismo Underbody Stabilizer Bars
Old Jan 13, 2004 | 05:39 AM
6MT_Coupe's Avatar
I looked at www.japanparts.com and found the Nismo stabilizer bars for approximately $600.. This is really expensive IMO... Plus, I would have to pay for an install... Does anyone have any information on where to get these two stabilizer bars for less than $500, and where could I get them installed in the Bay Area and for how much? Thanks
Here's to alcohol : The cause of ... and solution to all of life's problems.
- Homer Simpson
Old Jan 13, 2004 | 09:26 AM
wizawuza's Avatar
Re: Nismo Underbody Stabilizer Bars
there's a good thread on this in Wheels, Brakes, Tires and Suspension...
here's a linky
https://g35driver.com/forums/showfla...sed&sb=5&part=
Twlight blue/Willow 6mt.
It's here
Old Jan 13, 2004 | 11:00 AM
waijai's Avatar
i.love.gold
I bought mine for around $400... www.courtesyparts.com
Ivory Pearl coupe
Old Jan 14, 2004 | 01:19 AM
JustinP10's Avatar
We have them installed on our Project Coupe. It's a pretty straight forward install, didn't take much work at all as the car was up in the air getting some other stuff done at the same time. Eibach has a set available as well as Stillen with their adjustable set. www.infinitipa.zoovy.com has a list of some of the options available right now.
Hope this helps!
Justin McClanahan
Heavily Modified 95 Infiniti G20
Working on a G35 Coupe
www.InfinitiPartsUSA.com -> www.EverythingG35.com
Old Jan 14, 2004 | 02:27 AM
Gsedan35's Avatar
Here are all known sway bars for the G35/350Z and all known specs
Nismo:
front- *36mm (hollow core design, like the stock bar)
rear- *22mm (hollow core design)
*However the this same person got different measurement's than I got when I used a dial caliper on the stock bars. So I have to question the accuracy of the above measurements. But their all I could find.
Cusco sway bar
35mm front solid, not hollow
22mm rear solid, not hollow
Front sway bar has two settings of 20% and 37% stiffer then stock
Rear sway bar is 73% stiffer then stock.
$450 (can go lower,shop for best$$ I got mine for $395 shipped)
Stillen 5-way adjustable bars
35mm front hollow 22mm rear hollow (converting from 1 3/8" & 7/8")
Claimed adjustment range 7% to 70% (unknown if both front and rear barshave the same full 7% to 70% range)
$479
Mines Sway bars
Front 20% stiffer rear 30% stiffer
$699.00(OUCH!)
Eibach specs from Eibach.com
34mm hollow front 22mm hollow rear
Front bar is 2-way adjustable, rear bar is 3-way adjustable
$349 at www.gruppe-s.com
350EVO Sway bars 3-way adjustable front and rear
34mm front and 23mm rear solid bar construction, not hollow.
$545 shipped
Front bar
middle adjustment 11% stiffer
stiff adjustment 33% stiffer
Rear bar
middle adjustment 25% stiffer
stiff adjustment 53% stiffer
Hotchkis Tuning Sport Sway bars
Sway bar sets include front and rear bars, greasable bushings,
and brackets.
Front 1 3/8" (35MM) Hollow (Bar Weight 13.5lbs)
3 Position Adjustable
Rate Increase over stock
+9%,+32%,+63%
Rear 15/16"(24mm) Hollow (bar weight 5.5lbs)
+54%,+92%,+146%
$295
www.hotchkistuning.com/cgi-bin/EDCstore.pl?user_action=detail&catalogno=22413
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
