Camber - observation from forza motorsports II
Old Jun 21, 2007 | 11:51 PM
cloud's Avatar
Ok, people have said they run -2 or even -4 camber on the track. I know it's stupid to compare a video game to real life but there shouldn't be that much a difference.
I put a car at -2 camber front and -1 camber rear and cornered hard. With load on the suspension, the camber doesn't even come remotely close to 0 degrees. So wouldn't running -2 camber be overkill even for those who use them on the track? I believe we have to take the shocks/ spring stiffness into account too but can anyone give me a good explanation?
Old Jun 22, 2007 | 07:42 AM
panda007's Avatar
with a more negative camber, the tires can grip more during turns. however, there should be a balance of suspension settings as camber does not help with straight away grip, acceleration and braking, not to mention tirewear. to those who actually race, handling is a priority than going straight. i think -4 degrees is overkill, imho.
Old Jun 22, 2007 | 07:57 AM
redlude97's Avatar
are you looking at the camber on the inside or outside wheel? Negative camber helps the outside wheel maintain grip because the suspension on that side uncompresses in a turn adding positive camber. The negative camber is to account for that so the outside tire maintains complete contact.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
