StopTech BBK & 6MT Sport Wheels
Old Jul 3, 2007 | 08:30 PM
infiniteecho's Avatar
I know they fit on the 350Z with 17" or bigger wheels, but the question is will these fit on my 06 6MT with the sport wheels?
Has anyone done this? I have been reading the bremo thread and I saw Tim said his RB just fit. Does anyone know if the StopTechs are larger, smaller or the same size? I went with the 13" (332mm) rotors.
Probably should have asked this before I bought the kit.... So, if they are too close, a set of small spacers should do the trick no? Where would I get a set?
Old Jul 3, 2007 | 09:56 PM
bigwilly's Avatar
Print out the template from Stoptechs website it will give you an indication of what size spacer to get. I got the H&R spacers they are high quality and come with longer bolts.
Old Jul 3, 2007 | 09:58 PM
I unfortunately don't have the equipment or the space to take off the wheel and measure it. How much did the spacers run you and where did you get them?
Old Jul 3, 2007 | 10:24 PM
perry05G35's Avatar
The offset on the sport 18" is +45 I think so you'll need at least a 10mm spacer. Some else chime in on the offset of the sedan sport 18" I've long since sold mines. Are the H&R hubcentric that's very important when buying spacers.
If you are looking for an estimate on the cost of spacers though check out tirerack.com and ebay under their parts and accessory section type "G35 sedan spacers" or just "spacers" you can also find the specs on your 18" wheel there too I'm sure there are some up for sale.
Old Jul 3, 2007 | 10:39 PM
You think I'll be that far off!? Holy sh*t! I am looking at the fitment guide from stoptech. It looks like I will need 1.5" from the edge of the rotor to the inside of the spoke.
Someone want to measure if there is that kind of clearance?
Thanks for all your help so far...
Old Jul 3, 2007 | 11:22 PM
bigwilly's Avatar
Off the top of my head 10mm sounds about right. I ordered 5mm spacers for my wheels so they would sit more flush with the fenders, but I remember test fitting with the Stoptech template and I was still a few mm off so 10mm "should" work. The place that I got mine had horrible service so I can't recommend them, took them way too long to get them in stock and no one would ever call me with an update like they promised.
Old Jul 3, 2007 | 11:34 PM
Do you have a picture of your car on the same wheels with the 10mm spacers?
Old Jul 4, 2007 | 12:37 AM
G35Papa's Avatar
If the 06 sport wheels are the same as the 05's, they WILL fit over 332mm Stoptech, 4-pot BBK
That's what I'm running right now. There is literally a fingernail thickness space between the caliper and the rim spokes.
I'll go snap some pics for you.
Be right back
Old Jul 4, 2007 | 01:58 AM
G35Papa's Avatar
Some things to consider. I have an 03. I think the specs are the same as far as the placement of the rotors and suspension but I just wanted to put that out there.
When you do finally get the BBK on, put some masking tape around the calipers so as not to scratch them when doing the test fit with the wheels.
Here you go
Old Jul 4, 2007 | 03:58 AM
perry05G35's Avatar
That's too close for comfort I would still go with a 5mm spacer for peace of mind.
Old Jul 4, 2007 | 09:42 AM
Thanks G35Papa. I feel a bit better now knowing I don't need 10mm spacers...
Perry, why do you say for your comfort? The calipers and rim shouldn't be moving laterally in relation to one another, no? A friend of mine has a huge brake kit on his car and can hardly fit a piece of paper between the rim and caliper and hasn't run into any problems.
Old Jul 4, 2007 | 10:53 AM
G35Papa's Avatar
You're welcome
I've had this setup on for about 3 weeks now. I drive roughly 90 miles a day on my daily commute. No issues.
Your right infinititeecho, the rim and caliper will never move in or out from one another.
Old Jul 4, 2007 | 12:05 PM
perry05G35's Avatar
I mean for peace of mind I would go with a small spacer actually I would replace the rims all together if I were buying a BBK that's just my opinion but like they say...they are like aholes everybody has one... With my luck a rock, brake dust of any other object would get ludge in the rim and scratch the red paint up on the caliphers.
Old Jul 4, 2007 | 01:29 PM
ttrank's Avatar
Grocery getter
Wow that is close!
Looks great
Old Jul 4, 2007 | 05:50 PM
Chico's Avatar
Here you go
that is close bro...love that BBK.
