275/30/19 on OEMS fit?!
Old Jul 10, 2007 | 03:03 PM
joe603's Avatar
ugg.... bulgy tires on skinny wheels? I just don't get it. A 275/30/19 WILL throw off your speedometer/odometer readings. Good luck with that
Actually, they are even with the rim...using the 245 and 275/35-19's that is. With the 245/35 for the front and 275/35 rear, the speedo is almost dead on; the sizes are very similar to stock. The speedo will be about 1.2% off for the front and .7% for the rear. If you take treadwear into account there is no difference between the two sizes.
Using 275/30 size, the difference jumps to 4.5%...
http://www.bigcustomwheels.com/info_specs.jsp
Old Jul 10, 2007 | 05:37 PM
redlude97's Avatar
an 8.5" wheel should have no wider than a 265mm wide tire on it, and thats pushing it, you can see the bulge in your pics clearly, but as long as you are happy.....
Old Jul 10, 2007 | 11:19 PM
xXHotelCrazyXx's Avatar
Originally Posted by Ferrarimanic360
are your back tires 30's?
35's
Old Jul 11, 2007 | 10:15 AM
joe603's Avatar
Don't take my word for it...look at the optional tire sizes with tirerack.com
http://www.tirerack.com/tires/Option...20Transmission
You're right, instead of the tires being smaller than the rim, they are a .25 inch over. I think the added tire width, rim protection, and look are worth it. To each man his own...
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
mryogi
Aug 14, 2015 07:58 PM
joedaddy1
Jul 28, 2015 02:58 PM
