sway bars for sedan
Old Jan 20, 2004 | 07:40 AM
jimmcrae's Avatar
sway bars for sedan
What are a good set of sway bars for my sedan. I plan on putting different wheels and tires eventually. Wanted to start off slow...
Thanks
Old Jan 20, 2004 | 11:17 AM
Gsedan35's Avatar
Re: sway bars for sedan
Take your pic of these adjustable bars.
Cusco sway bar (These are the bars I am running on my sedan)
35mm front solid, not hollow
22mm rear solid, not hollow
Front sway bar has two settings of 20% and 37% stiffer then stock
Rear sway bar is 73% stiffer then stock. (rear not adjustable)
$395 shipped
http://www.gruppe-s.com/350z/zsus.htm
Stillen 5-way adjustable bars
35mm front hollow 22mm rear hollow (converting from 1 3/8" & 7/8")Claimed adjustment range 7% to 70% (unknown if both front and rear barshave the same full 7% to 70% range)
$479
Eibach specs from Eibach.com
34mm hollow front 22mm hollow rear
Front bar is 2-way adjustable, rear bar is 3-way adjustable
$349 at www.gruppe-s.com
350EVO Sway bars 3-way adjustable front and rear
34mm front and 23mm rear solid bar construction, not hollow.
$545 shipped
Front bar
middle adjustment 11% stiffer
stiff adjustment 33% stiffer
Rear bar
middle adjustment 25% stiffer
stiff adjustment 53% stiffer
Hotchkis Tuning Sport Sway bars
Sway bar sets include front and rear bars, greasable bushings,
and brackets.
Front 1 3/8" (35MM) Hollow (Bar Weight 13.5lbs)
3 Position Adjustable
Rate Increase over stock
+9%,+32%,+63%
Rear 15/16"(24mm) Hollow (bar weight 5.5lbs)
+54%,+92%,+146%
$295
www.hotchkistuning.com/cgi-bin/EDCstore.pl?user_action=detail&catalogno=22413
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jan 20, 2004 | 05:49 PM
Renesis's Avatar
Gsedan35
what stiffness did you put for your front sway bar?
Old Jan 20, 2004 | 07:58 PM
IQ9's Avatar
IQ9
I called Hotchkis today and they sales staff repeated" the directions state to use the stiffest setting to eliminate roll" and that was it. I hated the explaination but I purchased them anyway. The zerk fittings sold me. My Chevelle squeeks like crazy and I have no way of greasing the bars, so I thought if I can head-off the problem this time why not.They were $398.99+8.25%tax and $25 shipping. I hope they are red but Hotchkis has a bad habit of showing the parts power coated red and sending you black and stating that red is not currently avalible for your application. WTF...why is the brochure show red with no disclaimer?
03.5 Sedan/B. Silver/Prem/Winter/Aero/Tint/Rims
69 Chevelle Hard Top BB/4.11's/Posi
Old Jan 20, 2004 | 08:19 PM
jimmcrae's Avatar
Can anyone give me any type of comments about the sway bars they are runnng on their sedan...pros and cons...squeaks and thuds...etc.. thanks
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
