Is the hub bearing stressed more with larger spacers?
No. A 25 mm spacer would place more stress on your hubs than a 5 mm spacer.
What redlude97 is saying is, this: If your stock rim is 18x9 +40 offset, adding a 5 mm spacer would be no more stressful than going to an 18x9 +35 offset rim.
This is because adding a 5mm spacer onto an 18x9 +40 offset rim pushes the rim further out the same amt as running an 18x9 +35 offset rim.
If you added a 25 mm spacer onto an 18x9 +40 offset rim, you would now be running an equivalent 18x9 +15 offset rim which would stress the hubs more than 18x9 +35 or +40.
Terry_G35
Sep 10, 2015 08:17 PM
