Nitrogen Tires,I'm sold.
Old Aug 5, 2007 | 02:04 PM
w33ps's Avatar
Costco*
Old Aug 5, 2007 | 03:19 PM
WILLIE BEANS's Avatar
Originally Posted by Bigd2k6
I'm runnin' JDM air in mine and it made my throttle response lightning fast, doubled my gas mileage, got rid of all my rattles and fixed the volume glitch on the bose stereo.
I WONDER IF HELIUM WOULD MAKE THE CAR LIGHTER .??
HMMMMMMMMMM
Old Aug 5, 2007 | 06:09 PM
jmonsale's Avatar
HMMMMMMMMMM
non-flammable and non-combustible...anyone gonna try it?
Old Aug 5, 2007 | 06:30 PM
gtbigup01's Avatar
Originally Posted by GixxerSteve
I thought the purpose of putting nitrogen in your tires was the anti-corrosive factor because there is no water vapor in nitrogen. I think this idea that your car now drives like a Porsche just because of a different gas in the tires is purely psychological.
I won't be be quick to discredit the claim even though I haven't done it. As a helicopter mechanic in the army we service all tires with nitrogen instead of air, I'm thinking there is a reason for that. Maybe I should try it just to verify the claim as it is readily available for me. Is there some special thing I need to do before I fillit up?
Old Aug 5, 2007 | 06:36 PM
Mustang5L5's Avatar
I beleive it.
The pros to nitrogen in the tires are:
-Lack of corrosive oxygen - preserves the rubber better
-Larger molecules don't seep out as quickly as pure air. Tires stay filled to correct pressure longer
-Tends to stay cooler leading to more consistent pressures
Nitrogen is used in pretty much all aircraft tires. It is "better" than pure air.
However, with all that said, i still run regular air in my tire.
Old Aug 5, 2007 | 06:58 PM
burns420's Avatar
Originally Posted by Mustang5L5
I beleive it.
you believe it makes the car immediately handle better?
corrosion is prevented, but the reason they use it in aircraft tires is the changes of temp/pressures with altitude and location. they use it in race tires because they heat up fast and much hotter. even if you drove your G to its limit there would be no performance advantage running pure nitrogen over air.
Old Aug 5, 2007 | 08:17 PM
AgentAero04's Avatar
Originally Posted by NonAme
well unless some1 already went with nitrogen and know from personal experience that it doesn't really improve anything then your opinion is valaid. But since no1 here but the OP that has used nitrogen, i take his words over all you contradictors anyday.
Maybe i should haead to Cosco. How much did they charge for all 4 tires?
$24.00 including balancing.Re-fills are free,they give you an ID # you register online.Then anywhere that has Nitrofill your covered.And there is a noticable difference in ride in my opinion.
Old Aug 5, 2007 | 08:52 PM
Mustang5L5's Avatar
I didn't say anything about the car handling better.
Old Aug 5, 2007 | 09:41 PM
burns420's Avatar
sorry then, i thought you meant you believed the OP
Old Aug 5, 2007 | 09:56 PM
Kazaam's Avatar
LMFAO!!!!! maybe I need some of dat good nitrogen on front wheel of my bike!!!
Old Aug 5, 2007 | 10:16 PM
Mustang5L5's Avatar
Oh no, i don't think it makes a difference in handling at all. Like i said, i am running regular air in my tires. I beleive nitrogen has it's pros, but it doesn't impress me enough to spend $30 to get it in there
Maybe one day if i'm bored and have the cash i'll do it. But more than likely i'll forget about nitrogen in a day or two
Old Aug 5, 2007 | 10:22 PM
AthensBlueG's Avatar
Brian
When I was 7 years old and my mom bought me a new pair of sneakers, I SWORE that I could run faster because of the new treads on the sneakers!
This is no different. The car isn't going to handle different with nitrogen in it. lol
Old Aug 5, 2007 | 11:12 PM
And the moon is made of cheese.
It rides better!
Some people are slow to accept new ideas or technology.Like the world is flat.
Old Aug 5, 2007 | 11:20 PM
burns420's Avatar
It rides better!
wow, id figure someone with a car would know better
Old Aug 6, 2007 | 11:01 AM
  #30
G35_TX's Avatar
Actually the car can handle better with Nitrogen. The main reason is Nitrogen doesn't change tire PSI with temp. The hotter the tire gets, the higher the PSI gets. Just like racing, you need to play with your tire pressures to find the optimal one. Once you find it you have to keep changing it if the tire gets hot or cold to keep it handling good. With nitrogen it stays in that PSI whatever the temperature might be.
So in a way yes it can make the car handle better.
