In dire need of help w/ offsets!!!
Old Jan 28, 2004 | 02:37 AM
FrankieBallzzz's Avatar
Ok, here's what I'm looking at: Axis Milano wheels, 19 x 8.5/front and 19 x 9.5/rear with Bridgestone S03, 245/35/19 front and 275/35/19 rear. I spoke with Derek over at Spyeng.com, and he told me that no specific offset would be needed for the rear to fit over the brembos but that the front would need a 20 offset. Now, I need your advice on which offset to go with for the rear, if any. I don't want the rim too far inside the wheel well, nor do I want it to protrude too much. I'd like a stock, clean look, but I'm not sure which offset would do this for me. I installed the Tein S-Tech springs, so please keep rubbing in mind when answering this question.
I'm ready to order these wheels any minute, but just want to be sure to order the right setup, so any and all help will be GREATLY appreciated!!!
Thanks a lot,
Frank
Old Jan 28, 2004 | 07:53 AM
BillR's Avatar
Re: In dire need of help w/ offsets!!!
20 offset in the front is perfect.
For the rear use 23 to 25mm. That way the fronts and rears will look the same in the opening.
The offsets on my 19 X 8.5 (f) is 21
and the 19 X 9.5 (r) is 23
BillR
Old Jan 28, 2004 | 08:19 AM
Nismoboy's Avatar
https://g35driver.com/forums/showfla...&part=all&vc=1 dollar99 has some on his ride, his offsets were +15 in the front and +20 in the rear...
John H.
2003 Infiniti G35 Coupe 5AT-Ivory Pearl-Premium Pkg-Performance Pkg.
Old Jan 28, 2004 | 11:29 AM
Ok, cool. Now, since Axis does not yet make those offsets, should I get the rims drilled? Will the rim itself look bad if I do? Also, will the offsets you recommended adversely affect the stability and performance of the car, say compared to the stock setup?
Thanks,
Frank
