Pic Request: Sedans w/ wider-than-stock tires
Old Aug 15, 2007 | 11:06 AM
canucklehead's Avatar
Hi all,
As my OEM Turanza EL42s are nearing the end of their life (thankfully), I'm looking at new tires & sizes. Stock size was 215/55/17.
I want to go a bit wider, in the 225-235 range while keeping the OEM 5 spoke sport wheel on my '04 6mt sedan. I'll be going with a 225/50/17 (I know the diameter is slightly less) or a 235/50/17.
If anyone has made a change similar to this I would appreciate some shots to give me an idea of how the tires look on the rims.
Thanks!
Old Aug 15, 2007 | 12:09 PM
redlude97's Avatar
IMO, 235 on a 17x7 is somewhat pushing it, I've got that setup on my winter wheel package, and the rear definetely has some bulge to it
Old Aug 15, 2007 | 12:43 PM
yeah that's what i was thinking. the tire rep at TireTrends is recommending the 225/50/17 size and says it has proved popular with G owners. using the tire size calculator i see that some minor speedo error results from the switch, but not enough to cause concern.
Old Aug 15, 2007 | 01:24 PM
darnelled's Avatar
You can check the specs section at www.tirerack.com to see which tires are made for various rim widths. 225 was the widest I can remmember fitting on stock 17x7 rims. You'll need to get wider rims if you want more than that.
Old Aug 15, 2007 | 01:57 PM
g35john's Avatar
Im running 225/50/17 on my stock sports and its great. I think they look perfect but my speedo is reading a tiny bit high. About 3 mph off at 75mph.
Old Aug 15, 2007 | 02:04 PM
broke_as_ajoke's Avatar
I hate to jump off subject, but how much will going from stock 17 inch tires to 20'in effect the speedo?
Old Aug 15, 2007 | 02:06 PM
redlude97's Avatar
shouldn't make a difference if the tires are sized correctly
Old Aug 15, 2007 | 02:54 PM
oh ok.. thanks...
Old Aug 15, 2007 | 03:51 PM
great, just the type of info i'm looking for. any pics?
Old Aug 15, 2007 | 06:28 PM
ttrank's Avatar
Grocery getter
Mine is off less than ~0.7% with my 20's. A 245/35/20 and 275/30/20 is almost the exact same size as the oem tires.
Old Aug 16, 2007 | 10:23 AM
darnelled's Avatar
see http://www.miata.net/garage/tirecalc.html
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
Jeff T
Sep 30, 2015 02:00 PM
TurTLe*
Sep 29, 2015 01:43 PM
philthethrilloh
Sep 9, 2015 01:25 AM
