Too aggressive?
Old Aug 16, 2007 | 01:00 AM
escobar929's Avatar
the rear is perfect. the front is gonna need some neg camber but it will look sick!
Old Aug 16, 2007 | 08:25 AM
beangrower's Avatar
here's some pics of my 10.5 rear +17, 275/30/19, tein flex slammed...camber wasn't touched...although going that low...u obviously get more neg camber. fenders rolled. so u see, if u roll fenders...there will be alot of clearance....in fact...i got a +5 mm spacer on the rear which brings it to +12mm offset in the rear.
this last pic is my set up w/ s-techs
Old Aug 16, 2007 | 10:41 AM
G35Asian's Avatar
Thanks beangrower for the input!
Old Aug 16, 2007 | 12:12 PM
robzone's Avatar
Roll your rear fenders and you will be fine. Those offsets will be perfect! The DF210 is a low enough drop to affect the camber perfectly for that wheel set up.
Old Aug 16, 2007 | 12:44 PM
Triple8Sol's Avatar
Are you buying those Work wheels off that silver Z roadster? Those sizes should fit depending on your drop/camber/tire choice.
Old Aug 16, 2007 | 04:53 PM
G35Asian's Avatar
Thanks for all the input guys! I scrapped to wheel idea and am now going FI
Old Aug 21, 2007 | 01:00 PM
05BLACK6MT's Avatar
Will 305-30-19 fit?
what about 305-30-19 on gts with 10.5+18 lowered on MR coilovers on the lowest setting? Will these clear the fender?
http://www.wheelsmaster.com/rt_specs.jsp
Just plug in the OEM's # and then AM's#
according to wheelsmarter the new set up will moves 1.6" closer to the fender than OEM
Have anyone run 305/30/19 on the G????????
Old Aug 21, 2007 | 01:09 PM
gary c's Avatar
Wheel sizes vs tire sizes.....?
I'm running 10.5 in the rear with 275's and the wheel doesn't stick out like
the ones in the pic.......don't like the rim sticking out like that......"Ricer!"
Old Aug 21, 2007 | 02:02 PM
Ralph0064's Avatar
I think this should help!
DF-210's/ GT-S (+18) 275/35 ....Its tight in there. Def. need to roll rears.
^^^ damn those slammed G's are HOTT!!!
Old Aug 21, 2007 | 04:00 PM
Vinny@VTR's Avatar
nice pics there... which wheels are you going with any OP?
joeslates
Sep 11, 2015 11:19 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
