Wheel Spacer Problem / Question
Old Aug 18, 2007 | 07:32 PM
Daorge's Avatar
Well I was trying to install some spacers earlier today and I noticed something ive never seen before so I figure id ask here to hopefully find out the answer.
Whats that red painted nut sitting by the studs? Its in the way of the spacer so im hoping someone can help me out
Old Aug 18, 2007 | 08:34 PM
firefox's Avatar
Just remove it. That little screw prevents you from putting your rear wheels on the front (it hits the back face of the wheel so that you can't put it on). I would save the screw though. When you get around to replacing the rotors, they could be rusted on the spindle and difficult to take off. If you use that screw and tighten it all the way, it will break the rust and pop the rotor right off the spindle. That's the only other use of that screw.
Old Aug 18, 2007 | 10:24 PM
Polishthrust's Avatar
^ what he said... and hurry with some pics when youre finished.
Old Aug 20, 2007 | 12:45 PM
Daorge's Avatar
Thanks guys, I installed the spacers and everything went smoothly after that. I love the new look however now im getting a clunking type of sound whenever the car is in motion from the rear. Im wondering if the spacers are loose or if something else is causing it, any suggestions?
Old Sep 23, 2007 | 07:56 PM
clunking isnt good.. i hope u didnt use 5mm spacers.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
EasySausage
Jul 14, 2015 11:17 PM
