Wheels Size
Old Aug 27, 2007 | 03:47 PM
SUB-ZERO's Avatar
Originally Posted by aHero4Eternity
Can you take pictures? I'm curious to see how flush they are. Also, realize that when you put the tires on and the car is sitting and the ground that you will have some negative camber that will sink the wheels in.
28lbs is quite heavy for wheels. Is that the weight of the front or rear wheels?
28lbs is the weight for the rear wheels, the factory forged is 26lbs. I don't think that's that much of a difference (also wider).
-SZ
Old Aug 27, 2007 | 03:50 PM
SUB-ZERO's Avatar
Originally Posted by bfan13
gotta remember the negative camber when the car is on the ground
Yes, I considered the negative camber. I really like the way the stock wheels look and they don't stick out at all. These are a little wider and stick out just a bit more. I measured the stock 19" wheel while that car was jacked up in comparison to the aftermarket wheel and the factory 19" tucks in a bit more. I think I have pictures of a G with the same rims (35mm offset); when I get home today, I'll post it.
Thanks,
SZ
Old Aug 27, 2007 | 04:20 PM
redlude97's Avatar
Here is a 9.5 +5 with a 285/35/19.
Notice how it has at least 5mm of clearance from being "flush" with the fender. This offset is over 1" further out than your 9.5+35. That is why it is impossible that your wheels are flush with the fenders. Once again, please post a pic of your "flush" wheels
Old Aug 27, 2007 | 08:37 PM
SUB-ZERO's Avatar
I like them tucked but my drop will not be that low (350Z H-techs) so the camber may not be as agressive. I already have the wheels so I'm probably going to go ahead with the install. At worst, I'll just get a new set later on down the line.
Thanks
-SZ
Old Aug 27, 2007 | 09:50 PM
Z33 Track pack's Avatar
I am running 19X9.5 Front 19X10.5 rear +22 offset. No rubbing issue
Old Aug 27, 2007 | 10:05 PM
Calvin's Avatar
Overglorified Altima
when was rubbing ever an issue in this thread?
Old Aug 27, 2007 | 10:11 PM
redlude97's Avatar
Thanks
-SZ
Thats fine if you are happy with the offset and drop, just don't say they are flushed with the fender because that just isn't possible and is a misleading statement
Old Aug 28, 2007 | 06:57 PM
SUB-ZERO's Avatar
My statement was based on my observation and it really does look flushed with the fender. If I have time this weekend to remove the tire, I'll fit the aftermarket rim back on and show you what I mean.
Thanks
-SZ
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
