Wheels Size
Old Aug 23, 2007 | 09:02 PM
SUB-ZERO's Avatar
Wheels Size
Just to get clarification since I've read that they DO and that they DON'T fit from various members on this site, can someone please tell me the following:
1. Will the following wheels fit properly on my 2005 Coupe:
(REAR)19"x9.5"
Bolt Pattern: 5x114.3
Off Set: +35mm
2. What size and brand tire do you recommend?
Thanks,
SZ
Old Aug 23, 2007 | 09:12 PM
redlude97's Avatar
they'll fit, but be pretty tucked and look horrible IMO. You'll need at least 20mm spacers to make them look decent
Old Aug 24, 2007 | 02:37 AM
Calvin's Avatar
Overglorified Altima
terrible offsets, especially for 8.5/9.5 wheels.
Old Aug 24, 2007 | 03:21 AM
Gam3's Avatar
^what he said
Old Aug 24, 2007 | 06:25 PM
_G_'s Avatar
_G_
Your rear offset should be between +19 to +29, depending on the wheel.
...but they'll fit.
Old Aug 25, 2007 | 01:12 AM
SUB-ZERO's Avatar
Thanks for the info!
-SZ
Old Aug 25, 2007 | 07:18 PM
SUB-ZERO's Avatar
I fit the wheels today and they fit nicely. Basically, the rim is flushed with the fender if you are looking from the top. As soon as I get tires on them, I'll post pics.
Thanks,
Angel
Old Aug 25, 2007 | 07:48 PM
redlude97's Avatar
Thanks,
Angel
impossible. I've got much lower offsets and I'm not even flush
Old Aug 25, 2007 | 08:34 PM
Calvin's Avatar
what is your definition of "flush?" O.o
Old Aug 26, 2007 | 08:38 PM
SUB-ZERO's Avatar
Okay, I broke out the digital caliper and if I fit the wheel on, and look straight down from the top of the fender, the wheel sticks out about 5mm pass the fender; to the naked eye it looks flushed. They are surely not tucked in like others mentioned. The front wheels are pretty much dead even with the fenders. I was told by the seller that they were 35mm offset, I guess I could always measure the wheel and see what the offset is (I have to look up how to do that). I will post picks as soon as I get tires mounted since I was waiting to ensure they fit before I spent that cash.
The wheels are not very expensive (ADR) but they look nice with the 3in polished lip and black center. Although they are cast, they weight about 28lbs which is only about 4-5lbs heavier than the stock forged 19in wheels.
-SZ
Old Aug 26, 2007 | 10:54 PM
Calvin's Avatar
Can you take pictures? I'm curious to see how flush they are. Also, realize that when you put the tires on and the car is sitting and the ground that you will have some negative camber that will sink the wheels in.
28lbs is quite heavy for wheels. Is that the weight of the front or rear wheels?
Old Aug 27, 2007 | 03:16 AM
redlude97's Avatar
Did you measure them when the car was in the air?
Old Aug 27, 2007 | 02:45 PM
Triple8Sol's Avatar
Yup...
Old Aug 27, 2007 | 02:51 PM
bfan13's Avatar
gotta remember the negative camber when the car is on the ground
Old Aug 27, 2007 | 03:01 PM
superdds's Avatar
they are going to be tucked for sure. my last set of gt-c's were 8.5/9.5, +27,+24 and they were still tucked.
