rim size
Old Aug 25, 2007 | 12:43 PM
kamek89's Avatar
rim size
are the front and back stock 18" rims the same width size? i kno the tires arent. i am planning on taking one of the rims from the front and switching it with one from the back because the one in the front is a little damage or something because its making noise when im driving....so i want to try that b4 i take it to the dealer
Old Aug 25, 2007 | 12:52 PM
superdds's Avatar
yep...they are both 18x8. only the tire size is different.
Old Aug 25, 2007 | 01:49 PM
killahb36's Avatar
not to thread hijack but does this also hold true for the 17" oem rims?
Old Aug 25, 2007 | 03:07 PM
lowrider's Avatar
He's right, both 8" wide, but they aren't the same. The front hub has a protruding threaded stud that's installed to prevent installing the rear wheel onto the front. You must remove this in order to use a rear wheel on the front.
No. The fronts are 7.5" wide, the rears, 8" wide.
Lou
Old Aug 25, 2007 | 06:52 PM
Calvin's Avatar
Overglorified Altima
https://g35driver.com/forums/wheels-tires/70901-g35-factory-oem-wheel-sizes-offsets.html
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
