Sedan Wheel Offset Chart
Old Feb 1, 2004 | 01:31 PM
khsonic03's Avatar
Here is a chart of the wheel offsets for the sedan. I owe much thanks to THX723, because if he didn't post his chart, then I wouldn't have had any idea how to do this. My chart answers a few more questions that I had when I was trying to fit my wheels. My measurements are similar to THX's, but they do differ slightly. I measured at stock ride height from my sedan.
'03.5 Brilliant Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Clear Corners, Alum. Pedals, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way!)
Old Feb 1, 2004 | 01:39 PM
khsonic03's Avatar
Re: Sedan Wheel Offset Chart
Sorry about the low quality, if anyone wants a better version, I can send it via email. The lines in the version above are slightly distorted. I couldn't fit a larger size.
amg35's Avatar
Florida G35 Club
Do you think that a 8.5" +35 would fit inside the fender on the front?
Thanks,
amG35
2003 Silver Sedan
Old Feb 1, 2004 | 02:29 PM
khsonic03's Avatar
I think it would be close. If you plan on lowering, I would say yes, because negative camber would kick it in the extra couple of mm. If you didn't lower, it might stick out a little when looking at it. As long as you get a tire that doesn't stick out too far past the wheel lip, it would probably be fine. I know other people have done 8.5 +38 and have been fine, and supposedly Giovanna did 9" +35 all the way around.
Old Feb 2, 2004 | 12:00 AM
khsonic03's Avatar
Check out this post, too. I guess one of the guys had 20x8.5 with a +38 and it was rubbing, but he didn't say whether front or rear. It depends on the tire width, etc. as well, however.
https://g35driver.com/forums/showfla...sed&sb=5&part=
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
reaper76
Aug 5, 2015 10:13 AM
