Tire Pressure Light On....@%@#
Old Aug 29, 2007 | 04:17 PM
LjN_728's Avatar
^ Check the sidewall for its max pressure. Potenza 19's are 44psi. If yours is the case, 40psi in high temps is okie dokes.
Old Aug 29, 2007 | 07:07 PM
BW350GTskyline's Avatar
once they drop 30lbs they through the light
Old Aug 29, 2007 | 08:10 PM
sfgr415's Avatar
Originally Posted by Grace
Do invest in a pressure gauge. I ignored my tires figuring the sensor was bad and later didn't know about a nail in it. (The next morning it was quite obvious....lol) Now I check pressure every fill up or so.
Can you say paranoid?
I wouldn't say paranoid. Especially since you are running on those beautiful JLines.
Old Aug 29, 2007 | 08:18 PM
Rphillips6487's Avatar
my tire pressure light is currently on as well, my tires are almost bald though so Id advise you take a better look at your tires
Old Aug 30, 2007 | 10:48 AM
Grace's Avatar
Avoiding potholes
Thanks!
I've never been so happy with my choice of rims before.
I usually get bored and change them out in a year or so.
Not these.
Old Aug 30, 2007 | 10:59 AM
oneshot's Avatar
Originally Posted by kyu1021
Check your manual.
open your driver side door and look at the sticker located on the door jam. it will tell you what pressure you should be running. and if that doesn't help, check your manual also. usually it's filled with very useful information.
I have checked my manual. My tires say Max 50psi. No way am I putting 50psi on stretched tires :/ I had a nail in my tire but the shop said they fixed it when they put my new wheels on. I guess I'll just put over 35 in the tires.
Old Aug 30, 2007 | 11:35 AM
joe603's Avatar
Never, Never put the MAX air pressure in the tires! When you drive, the heat will increase to beyond the MAX and you could have a blowout. The DATA plate on the drivers' side door jam is the OEM recommended pressure for the front/rear tires. Follow that, even with aftermarket. (unless you drag, then the rears should be low)
Old Aug 30, 2007 | 11:51 AM
myDOORSgoUP's Avatar
have your tires filled with nitrogen and you will never have a problem....nitrogen doesnt expand with heat so your pressure will not vary with temp, only if there is an actual leak somewhere...
Old Aug 30, 2007 | 01:06 PM
GPang's Avatar
I have rims from the factory that i've never seen on a Stock G35 before.
They are Black / Chrome Finish.
They put Eagle tires on my rims....dunno if that rings a bell for you guys.
never heard of it.
Old Aug 31, 2007 | 12:55 PM
sliq's Avatar
aite.. dont feel like reading all these replies, but i had the exact same problem the SAME day i bought my G. what happened was they might have had a different set of tires/rims on the car before they sold you it and had that set pressure on the old one. uh... dont feel like explaining anymore, but basically take that **** to ANY infiniti dealership closest to you and theyll fix it. **** takes like... 20 mins to fix. if youre driving a 6spd G coupe keep your tire pressure at around 35psi. jus take it to the dealership, itll make your life a lot easier
Old Aug 31, 2007 | 01:10 PM
redlude97's Avatar
right....quick question, what percentage of air is nitrogen again?
Gotta love the magical gases that don't expand with temperature, guess my chemistry 101 teacher should be fired....
Old Aug 31, 2007 | 01:20 PM
GPang's Avatar
Fix It For Free Right? I Do't Want Them Charging Me For **** That I Didn't Do.
Old Aug 31, 2007 | 02:56 PM
lol w/e im not a scientist but i do know that i have never had a problem with my pressure, on stock 18's and aftermarket 19's (both filled with nitrogen)....and i know that the nitrogen prevents dry rot on the tires when they are sitting without use...
jsimonk
Dec 22, 2023 03:49 PM
Fireman07603
Aug 9, 2015 06:00 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
