18x8 wheels/tires/offsets?
Old Feb 4, 2004 | 12:37 PM
tedtf's Avatar
I wnat to upgrade to some 18x8 wheels for summer and keep my oem 17s for my blizzacks during winter. Anyone out there give me some advice on what tire size works and what offsets work? I was thinking 18x8 wheels with 245/4018 tires and 45 offset. By the way...what is stagger? I like the Axis milanos, ame schrift, and work ts2......for wheels.
2003 Brilliant Silver Sedan 6MT
Old Feb 4, 2004 | 08:41 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: 18x8 wheels/tires/offsets?
If you're going to go with 18X8s why not just pick up some coupe 18s real cheap. They won't be as nice as a set of axis or works but you'd probably save $1500 for some under the hood goodies and you're still getting a customized look.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 5, 2004 | 06:13 PM
lowrider's Avatar
There is no stagger built in on the sedan, like there is on the coupe. Don't worry about it. As far as offset, I don't know much about the sedan, but I'd stay pretty much close to stock.
Lou
Old Feb 5, 2004 | 06:36 PM
khsonic03's Avatar
You can stagger the sedan. That is when the rears (usually) are wider and/or stick out further than the fronts. Here is the chart I made:
https://g35driver.com/forums/showfla...sed&sb=5&part=
'03.5 Brilliant Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Clear Corners, Alum. Pedals, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way!)
Old Feb 6, 2004 | 12:29 AM
tedtf's Avatar
Will hp evos 18x8 with a 38 offset be okay for all four corners? I am concerned about getting the correct offset. I saw your chart-thanks its very helpful. If I understand correctly there won't be a problem with clearance with a 38 offset, just the tires/wheels sit farther out towards the fender, they won't hit anything? Correct?
Old Feb 7, 2004 | 01:59 PM
big_h's Avatar
Hi,
they will be fine.
If you want HP's, I have a deal on them. PM me for info.
http://www.bigwheelz.com/
shavedcrx
18 Inch
Dec 29, 2015 07:39 AM
CrazyLogic219
Sep 24, 2015 09:59 PM
derres
Aug 28, 2015 03:27 PM
cbax
Aug 17, 2015 07:41 AM
reaper76
Aug 5, 2015 10:13 AM
