will these tires fit my OEM's 19?
Sep 27, 2007 | 01:43 PM
Has anyone had a problem running these on their OEM 19 coupe wheels?
235/35-19 and 255/40-19
falken fk452's
It's time for new tires and these seem like the best buy...
thanks!
Reply 0
Sep 27, 2007 | 01:49 PM
yes that should work. The stagger % remains the same at 2.4%.But both tire's diameters are slightly larger.
Reply 0
Sep 27, 2007 | 02:00 PM
well according to miata tire size calculator... the front will be running 2.3% faster and the rears 1.2% slower... will that make my VDC go nuts?
Reply 0
Sep 27, 2007 | 02:02 PM
Oh wait. That's right. I thought you were going 235-40-19. Sorry. I think that combo might create a VDC problem. Maybe.
Reply 0
Quote: yes that should work. The stagger % remains the same at 2.4%.But both tire's diameters are slightly larger.
You sure you plugged that in correctly buddy? 235/35/19 is shorter than stock, 2.3% to be exact. The stagger also becomes 5.78% difference. Not acceptable IMO. You should get a 245/35/19 in the front, or stick with the stock sized 225/40/19
Edit: beat me to it, you're lucky I got distracted
Reply 0
Sep 27, 2007 | 02:08 PM
As sure as Tito is not gay bro.
Quote: You sure you plugged that in correctly buddy? 235/35/19 is shorter than stock, 2.3% to be exact. The stagger also becomes 5.78% difference. Not acceptable IMO. You should get a 245/35/19 in the front, or stick with the stock sized 225/40/19
Reply 0
