New tires installed on OEM 19", rear looks odd
I wonder why I didn't notice the negative camber with the stock Potenzas...do you think it is mostly due to the wider tires that makes it more apparent?
I keep feeling that the left has more negative camber than the right for some reason...it bothers me but I trust that all is normal and that I'm just being paranoid.
This is weird for a stock height tire replacement. I used to have 265 PS2s and then 255 Falken 452s on my OEM rear 19"ers... I didn't have negative camber like your car does at all. Just go get an alignment, and that should fix it. Getting a bigger tire shouldn't effect camber like that. If you dropped it, that's another thing...
If you bought your car used or from a private seller, maybe they changed the springs, although your car doesn't really appear to have a drop on it....
wow, that's weird i have 225/40 on the front (stock) and 255/40 on the rear. My tires look way wider than yours. I do have a bit of negative camber but not as much as yours.
I can't decide whether I liked the 245 better or the 255... I'm thinking I should have gone with 275/35 maybe... anyone else got 255 on the rear with stock 19s? just curious to know if you like the setup
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
FS[Canada]: 19" Rays Volk LE37 Wheels Rims with Falken Tires
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
