wheels spacers???
Old Nov 14, 2007 | 06:38 PM
redlude97's Avatar
Originally Posted by TwilightBLUES
i believe after some research the offset is +45
19x10+45? I would run 25mm spacers at a minimum, but even that will still be somewhat tucked.
Old Nov 14, 2007 | 07:27 PM
TwilightBLUES's Avatar
thanks for the response redlude, i have no clue about spacers at all.
ima go to my local shop n have them take a look. So now i can have a background to what i should look for, 25mm or more...
Old Nov 15, 2007 | 06:34 PM
by15vc's Avatar
with a 10 width and +45 offset..personally i would run at least 30mm spacer to bring it to +15. u can run a 25 but it'll still be a little conservative given that its a 10 wide with +20. if you don't mind running an aggressive setup with slight camber i would say do a 35mm
Old Nov 15, 2007 | 09:42 PM
yea i want it to be aggressive, F1 told me about a 100 for the h&r spacer kit.
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
