Coupe wheels and BBK
Old Nov 15, 2007 | 03:40 PM
03Sg35's Avatar
Will I have any issues running F BBK and rear stock brembo on my sedan with coupe 18".?? This would be a winter setup while I have the 19" for nice weather. Anyone run that set up ???
Old Nov 15, 2007 | 05:19 PM
FlyingLumpia's Avatar
You should have no problem since the coupe with the brembo use those wheels anyways. I am running my stock 17 with a 5mm space which makes it a 40 offset and these alittle room, but with the coupe 18 at a 30 should not be a problem like I said. But if I am wrong someone correct me quick.
Old Nov 15, 2007 | 05:20 PM
ttrank's Avatar
Grocery getter
^+1
Should fit fine.
Old Nov 15, 2007 | 06:39 PM
03Sg35's Avatar
Thank you, now I just need some decent winter tires
Old Nov 15, 2007 | 08:10 PM
G SEDAN's Avatar
should come out nice! I was going to ask if you made sure it would clear your 19's too...but seening taht you ahve the axis shine, there shouldnt be a problem.
Old Nov 15, 2007 | 08:11 PM
Jeff92se's Avatar
Red Card Crew
I wonder if he could even get away with using the Z 17s? Would make buying snow tires that much cheaper.
Old Nov 15, 2007 | 08:22 PM
ttrank's Avatar
Grocery getter
You should be able to. The oem kit is a 12.8" rotor with 4/2 pot and will clear 17's.
Old Nov 15, 2007 | 09:14 PM
03Sg35's Avatar
I got the Gran Turismo kit 14" 2pcs rotors, it looks huge, well the calipers do. I have my stock 03 17s also. I figure I get 18s cheap and use them as winter set up. I was planning on using 15mm or 20mm spacers on the Axis just to push them out a bit.
Old Nov 15, 2007 | 10:18 PM
ttrank's Avatar
Grocery getter
The Brembo 14" (355) kit won't fit with 17" wheels...
Do you mean the 332mm kit?
Old Nov 15, 2007 | 10:47 PM
03Sg35's Avatar
No its the 355mm kit
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
mushu
Jul 15, 2015 03:55 PM
