snow tires on oem 19's
Old Nov 18, 2007 | 08:19 PM
texasranger2003's Avatar
i have an 05 AT coupe with stock 19's and sport tires, what are my winter tire options for these 19's? I'd rather not have to put on a diff set of wheels for winter.
thanks guys
Old Nov 18, 2007 | 08:57 PM
Loe G35's Avatar
Here is a set with matching OEM sizes http://www.tirerack.com/tires/Compar...29&RunFlat=All
Research if you can use 225/45R19's in the rears instead (I've used 225 widths before on my 8.5" wide rear rim on my BMW). The skinner tire you can mount on rims the better. The fronts are already at the minimum IHMO, going down to a 215/45R19 would be risky (not to mention probably impossible to find that tire size).
I'm just thankful that I have the OEM 17's to use my blizzaks on and have OEM 19's for 3 seasons. The cost of the tires on the 19's are murder
Old Nov 18, 2007 | 09:02 PM
patman530's Avatar
you should look into getting some oem 17's, it's hard enough trying to find stock sizes for oem 19's for summer tires
Old Nov 18, 2007 | 10:28 PM
thanks guys, i appreciate it, im gonna go with the lm-25's in the stanard stock sizes.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
bjo16
Aug 4, 2015 09:52 AM
