Steering Wheel issues
Old Nov 26, 2007 | 01:46 PM
NJNoob69's Avatar
I just had my tires and wheels placed in the winter but for some reason my steering wheel starts shaking at around 40mph... does anyone have similar problems?
Old Nov 26, 2007 | 03:32 PM
G35fromPA's Avatar
Have your tires rebalanced by the place that installed them. If that doesn't solve it, you may have a bent wheel. If neither of those is the culprit, could be a suspension piece. Can you tell approximately which side has the vibration, and do you experience it only under braking, or all the time?
Old Nov 27, 2007 | 01:36 PM
NJNoob69's Avatar
I don't think it has anything to do with the wheels...they don't vibrate while driving. The steering wheel is the only issue..
I'll give it a shot and let you know.
Thanks!
Old Nov 27, 2007 | 04:00 PM
G35fromPA's Avatar
I suppose it could be something in the steering linkage, but that seems unlikely unless it was damaged. Are you sure the place that put on the winter wheels/tires torqued the lug nuts back down?
Here are some other suggestions, though they are fairly generic:
http://wiki.answers.com/Q/What_cause...steering_wheel
Old Nov 27, 2007 | 04:37 PM
kvangil's Avatar
Most likely, it's wheel-related and not your steering wheel itself.... Sounds like the wheels need balancing. unbalanced wheels will cause your steering wheel to shake. So would bent wheels... If the steering wheel shakes all the time, even at slow speeds, mostly it's a bent wheel. If it shakes at certain speeds (say 40mph+), most likely wheels need balancing. If it shakes during braking, most likely brakes.....Good luck...
kd03g99
Jul 30, 2015 11:24 AM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
