Offset with brembos 20x8.5 35mm??
Old Feb 29, 2004 | 12:22 AM
willthethrill's Avatar
I did some searching but couldnt find my answer so i apologize, but will wheels that are 20x8.5 35mm offset clear the brembos on my coupe?
Thanks in advance!
Old Feb 29, 2004 | 12:28 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: Offset with brembos 20x8.5 35mm??
I don't think so. I have 8.5s on the front of mine with a 21mm offset and you can get a couple sheets of paper between the wheel and Brembos if you're lucky.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 29, 2004 | 11:08 AM
Would a 20mm offset fit then. Those are my two options 35mm or 20mm. Maybe i was thinking about it wrong.
thanks
Old Feb 29, 2004 | 12:14 PM
lowrider's Avatar
It really depends on the shape of the spoke or mesh or whatever the face of the wheel is, as well as the offset. My Nismos are +25 in front and I can almost get my hand between the brembo and the wheel, the front spokes stick out a little, while the rears are recessed. But, yes +20 is probably OK for the front.
Lou
Picture Share
Feb 4, 2018 12:41 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
TurTLe*
Sep 29, 2015 01:43 PM
ChickenTendrs
Sep 16, 2015 01:10 PM
