Aggressive Offsets - Will it Fit?
Old Dec 7, 2007 | 03:54 PM
heyitzalex's Avatar
Aggressive Offsets - Will it Fit? - SEDAN
So i am looking into getting a set of new wheels, JP Scaras, and there are some that I am interested in. Before anyone makes any remarks saying there is absolutely no chance that they will fit, I will be getting my fenders pulled, running neg camber and running a big stretch.
So the offsets are
19x9.5 +35
19x10.5 +24
They are currently on 245/30s, but I will probably change the front to a 215.
From what I have now, 19x8 +35, 19x9.5 +45, my rough calculation gives me the answer that the new wheels will stick out 0.7 in more in the front, and 1.5 in more in the rear, if I remember correctly. I consider my offsets right now pretty conservative, they are no where near my definition of "flush".
Will these wheels hit the inside suspension? I can't find the offset chart that was posted here once.
I'm either going to go with these wheels or get new barrels and lower to offset on my current wheels. Any input will be appreciated.
ttrank's Avatar
Grocery getter
Nope, not on the sedan. I highly doubt you will be able to get those to fit.
Old Dec 7, 2007 | 03:56 PM
93 til Infiniti's Avatar
+1
I dont think itll fit.
Here is what I know of as the preferred for our sedans:
19x8.5" in front with a 35-40 offset (38 is optimal), and 19x9.5" in rear
with 40-48 offset (45 is optimal).
Old Dec 7, 2007 | 03:57 PM
heyitzalex's Avatar
there is only one g sedan on vipstylecars.com that gets props for his car and his calculation says that the most we can go on our cars is 19x9 all around +30 front +18 rear. I asked him and he said it should work but I'll wait from your guys' input first.
My current set up:
19x8.5(+40mm) 245/35
19x9.5(+45mm) 275/30
If my rear went any lower (sitting on H-techs) then I know I would have to shave/roll the fenders to clear the height.
Old Dec 7, 2007 | 03:58 PM
heyitzalex's Avatar
im going to wait for gdup's input
Old Dec 7, 2007 | 05:02 PM
GeeDM's Avatar
My rims sizes and offsets are
19x8.5 +38
19x9.5 +38
235/35 in front
265/30 in rear
NO rubbing issues at all
Old Dec 7, 2007 | 05:05 PM
Tunerz_Store's Avatar
i hope you plan to make it a wide body kit, because that 10.5 "aint" gonna fit.
Old Dec 7, 2007 | 06:21 PM
VQ Hotness's Avatar
Idk man ive got a 10 in the rear with a 43mm off set. And it very flush with the fender. Your going to get a half inch wider rim and push the rim out an extra 17mm. I dont think this is going to work, Actually it will work but it wont look good.
Old Dec 7, 2007 | 07:05 PM
FlyingLumpia's Avatar
My buddy with a Z we were talking last night and we are going to try and put his wheels on my car for fun. They are meinsters 19x9.5 +17 in front and 19x11 +17 rear I think. I will take pics when we do this.
Old Dec 7, 2007 | 07:09 PM
Klubbheads's Avatar
With more than -2.0 camber and 245 tires in the back i say it is possible in the back with completely shaved fenders.
Old Dec 10, 2007 | 02:11 AM
(>")> G35's Avatar
I think those specs are doable, you may need a small spacer on the front so it wont rub up against the front knuckle. No doubt you'll rub on the unmodded fenders, but I guess that would depend on the camber and fender roll/shave/pull to fix that.
Here's member running:
Work Euroline S2H
19x9 + 26 225/35
19x10 +26 265/30
The new sedan pretty much runs the same specs, his front is 3mm more aggressive, but it'll probably be the same with the spacer. Your rear is going to stick out 8mm more than his and you'll have plenty of room inside.
Old Dec 10, 2007 | 03:25 AM
heyitzalex's Avatar
Work Euroline S2H
19x9 + 26 225/35
19x10 +26 265/30
That is a sick sedan! Man, I'm debating if I should go for the wheels or not. It would be a bummer if I got them and they didn't fit but I am sure that I can get it to work
Old Dec 11, 2007 | 06:46 PM
the 07 sedans are more for giving on offsets than previous gen.
Old Dec 11, 2007 | 06:50 PM
Cost a G's Avatar
I think you may get away with 10.5 + 24 in the back. Run some 255s with fender roll
