What is the metal tab between lugnuts?
my sf winnings wont fit, tried putting on my front rim, but wouldnt fit over a couple of the lugnuts. there is another bolt between the lugnuts that prevents the lugnuts from going all the way on. please help.
Re: What is the metal tab between lugnuts?
The shorter little metal bolt that you see on the fronts between the lugs are guide pins. They are there so you don't put the rear wheels on the front. I had mine taken out when I had my rims put on. You don't really need them.
Hope that helps. If you don't trust me, take it to professionals like Discount Tire and they will tell you.
Damnz2z is correct. You need to remove them.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Russ
Black 6MT Coupe
Jax, FL
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
