9.5-Inch Wheels up front...
Old Dec 23, 2007 | 03:57 PM
OH6 G35's Avatar
Is anyone running 9.5-inch Wheels up front?
If so, do you have any "interference" problems?
Also, what offset are your Wheels?
...any 18-inch Wheels??
Old Dec 23, 2007 | 10:32 PM
adrenaline rush's Avatar
As I understand, yes, 9.5's will fit up front. Something in a 20-28mm offset should fit.
I am looking to go non staggered when I get new tires and was thinking of going 9.5 all around.
Old Dec 25, 2007 | 12:45 AM
OH6 G35's Avatar
Does running 9.5s up front really slow-down steering?
Anyone running these??
Old Dec 25, 2007 | 01:38 AM
O HELLA JDM's Avatar
i know a few people running 9 in front and either 10 or 10.5 in the rear...but i dunno
Old Dec 25, 2007 | 09:05 PM
aleok's Avatar
9.5f, 10.5r is a very common aftermarket rim set up. i didn't notice any difference in steering.
Old Dec 25, 2007 | 10:22 PM
OH6 G35's Avatar
I would imagine that 9.5 up front would slow-down steering a little but 10.5???
Old Dec 25, 2007 | 10:59 PM
Skaterbasist's Avatar
Retired SuperMod
If you carefully read his post, it says 9.5f, 10.5r. As in, 9.5 front & 10.5 in the rear. And he's right, 9.5f & 10.5r is a very common setup for Coupes.
I myself will be getting 9.5 in the front & 10.5 in the rear. You can run 245 or 255 rubber on the 9.5 fronts without a problem. As far as offset, im not sure which one would give you issues up-front. But the "usual" & more common offsets for 9.5 fronts should fit just fine.
I suggest you look for people with similar setups. That's what I did before deciding on which size (width) & offset for the wheels I will purchase [in the future] for my car.
I know im being a little vague, but I hope this helps out
PS. The wheels I decided upfront are 9.5 +17 offset. They will fit just fine.
Old Dec 25, 2007 | 11:02 PM
GLuXuRy's Avatar
9.5 up front is fine ... some guys run a 9.5 up front with a +10 offset and its fine .. steering is same .. maybe a lil less on the turning ratio .. but no biggie
just slap those 9.5 up front and drive your baby
Old Dec 25, 2007 | 11:18 PM
Calvin's Avatar
Overglorified Altima
9.5f/10.5r is probably the most common/popular after market setup for the coupe.
Old Dec 26, 2007 | 01:11 AM
OH6 G35's Avatar
Ooops, my bad!!
He did mention 10.5 rears!
I was wondering about the 9.5s and "rubbing".
Lock-to-lock...any??
Old Dec 27, 2007 | 12:46 AM
Triple8Sol's Avatar
I had to recheck the date of this post. I couldn't believe my eyes when it wasn't pre-2004
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
