Installed H&R 5mm Spacers Without Replacing Studs
Old Dec 23, 2007 | 10:18 PM
07 G35S Sedan's Avatar
I installed H&R 5mm spacers on the rear of my G35 sedan without replacing the factory studs with the longer studs. I realize it's recommended to replace with the longer studs. Although is it safe to run with the factory studs?
Old Dec 23, 2007 | 10:26 PM
codeflux's Avatar
no, it is not safe. get longer studs, or pull your spacers. end of story.
Old Dec 23, 2007 | 10:28 PM
OH6 G35's Avatar
...+1
Old Dec 23, 2007 | 10:34 PM
Why is it not safe? Will the lug loosen? What else can happen?
Old Dec 23, 2007 | 11:08 PM
ashish's Avatar
you dont have as much thread left for the lugnut to grab on to with the added 5mm. You run a risk of the lug loosing and falling off.
Old Dec 23, 2007 | 11:17 PM
Can you provide a link on how to install remove and replace the rear studs on a 07 G35 Sedan?
Old Dec 24, 2007 | 12:28 AM
OH6 G35's Avatar
...how I did mine!
http://www.my350z.com/forum/showthread.php?t=263033
Old Dec 24, 2007 | 01:31 PM
[QUOTE=OH6 G35]...how I did mine!
So on the rears I have to unbolt the center hub bolt to remove the rotor, correct? Unlike the front where the rotor is free floating. Also what tool did you use to install the wheel studs? Please advise.
Thanks!
Old Dec 24, 2007 | 04:03 PM
OH6 G35's Avatar
Originally Posted by OH6 G35
...how I did mine!
Thanks!
NO! Do not remove the center Hub Bolt!
At first, I thought about removing the Wheel Hub / Bearing Assembly but then decided against that idea. This requires too much additional work that isn't necessary. Once you remove the Wheel, you may have to back-off the Parking Brake Adjuster (that's if the Rotor doesn't slide right off). Wheel Studs were installed with just a Socket (that goes over the Stud and acts as a spacer), a Nut and a Socket Wrench (as pictured above).
Old Dec 27, 2007 | 12:46 AM
Triple8Sol's Avatar
No need for longer studs with 5mm spacers imo. I've run it, and the lugnuts still have more than enough threads to be safe.
Old Dec 27, 2007 | 11:38 AM
How long have you been running with 5mm spacers? Also do you find yourself having to retorque the lugs more than usual?
Old Dec 27, 2007 | 12:03 PM
ttrank's Avatar
Grocery getter
IMO anything over 3mm needs longer studs. Just get the nismo studs and be safe.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
si_driver
Jul 14, 2015 12:29 PM
