Tires and Rims
Old Dec 25, 2007 | 12:33 AM
G35_Girl_69's Avatar
Tires and Rims
Wow I haven't been on here in a while. You guys helped me out a lot last time so let's see if you can help me figure this out.
I have a 2003 Infiniti G35 Sedan. I want new tires and rims someone please tell me if this setup will work. The car is not dropped and I do NOT want to roll the fenders. I did a lot of research but am still confused a bit. Positives and negatives of this setup would help me decide, and suggestions always welcome!
Front:
Tire: Falken 452 - 245/35/19
Rim: Falken Koblenz Wheel 19x8.5 Bolt Pattern 5x120 +38 Offset
Rear:
Tire: Falken 452 - 275/30/19
Rim: Falken Koblenz Wheel 19x9.5 Bolt Pattern 5x120 +45 rear Offset
Old Dec 25, 2007 | 01:10 AM
perry05G35's Avatar
Those are the wrong bolt pattern. You will need a 5x114.3 the offsets are fine though you will not need to worry about rolling your fenders with those offsets. The tires will work too but i'm pretty sure that once you see the wheel gap you will probably drop your car about 1 inch. Does your 03 have the sports package?
Old Dec 25, 2007 | 01:57 AM
I'm not sure what the Sports package is so I doubt it. There is no +45 offset in that bolt pattern.
What about this one:
Wheel Specifications:
Front Size: 19 x8.5
Rear Size: 19x9.5
Bolt Pattern: 5x114.3
Front Offset: +25
Rear Offset: +35
If this doesn't work what is a combination that I can make work? Here's the link with all the different sizes available.
http://www.falkentire.com/koblenz_sizes.html
Old Dec 25, 2007 | 04:04 AM
perry05G35's Avatar
The 19x8.5, 5x114.3 with a +35 mm offset for the front
The 19X9.5, 5x114.3 with a +42mm offset for the rear
Only problem is based on the specs you listed seems like you are looking for these in black/chrome and the only way you will be able to get them in that style is to go none staggard in the rear with a 19X8.5 +35 for all 4 rims.
You could get the +35 in the rear but you will need to roll your fenders, dial in negative camber, lower the car and get a smaller tire a 255 instead of a 275. With out a drop though the +35 in the rear will stick out too much from your rear fender line.
Old Dec 25, 2007 | 10:31 AM
NathanJax's Avatar
..... I WIN .....
Here's a Rim/tire thread that was helpful to me.
https://g35driver.com/forums/wheels-tires/191297-rim-sizes-do-19inch-coupe-rims-damage-sedan.html
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Jussumman
Dec 22, 2015 10:23 AM
Fire0nic3
Aug 31, 2015 03:18 PM
BlackGee35
Jul 31, 2015 11:04 AM
