Getting Some VS-XX's - Offset and Tire Q's
Old Dec 31, 2007 | 11:18 AM
  #31
trueskillz12's Avatar
Originally Posted by intense660
hows your rubbing in the front? im thinking about gettting the same specs as urs but a larger lip..
btw ur rear is cut? explain? did you cut ur fenderliner to ****s? and roll the fender? would you suggest a higher offset if you don't wanna do fender modification? or would you have to go down a half inch?
there is no rubbing in the front
rear fender is cut
if you dont want to mod your fenders you gotta go with higher offsets but then you wouldn't get any lippage
here are the pics i took 10 minutes ago
sorry about the quality apparently photography isn't 1 of my skillz
ARC!!!
HKS RS!!!
Old Dec 31, 2007 | 12:27 PM
  #32
MIA BlazinVQ's Avatar
brb getting cut
^nice! whats that front lip again? 2.4 front and 4.4 rear?
Old Dec 31, 2007 | 12:43 PM
  #33
Hexxum001's Avatar
Just keep one thing in mind bro. If you go aggressive for max lippage (like Calvin), you can rule out getting a BBK. So if you ever want a BBK, you can't go that aggressive. I am eventually going to get a BBK on the front for sure. I'm not sure about the rears though because my drag radials won't fit with a BBK on the back.
Old Dec 31, 2007 | 01:25 PM
  #34
brb getting cut
^ do you by any chance know what's Calvin's front lip is? I dont think i 'll be getting a BBK for a couple of years to come.
Old Dec 31, 2007 | 08:40 PM
  #35
yea those are the lip sizes
the front +28 will fit most BBKs out there
the stock brembo requires a 3mm spacer
i've seen many people with rear BBKs on +17 but you would have to check with a vendor to be sure
tires affect BBK fitment?
Old Jan 1, 2008 | 10:20 PM
  #36
brb getting cut
hey trueskillz what are the specs on your tires they look so 'beefy', I prefer it to look more low profile. maybe its the pics though
Old Jan 2, 2008 | 02:34 AM
  #37
front 255/35/19 toyo t1r
rear 285/35/19 toyo t1r switching to 275/35/19 soon
i like the beefy look but at the same time i want a lower drop and dont want to swtich to the 30 series tire.
Old Jan 2, 2008 | 02:39 AM
  #38
brb getting cut
Edit: nevermind, I found out.
Old Jan 17, 2008 | 09:10 PM
  #39
brb getting cut
bump. if anyone knows off the top of their mind... do VS-XX's offer a chrome or polished lip? Also, if anyone has any pics to show the difference
I would appreciate it (they both look the same to me).
Old Jan 17, 2008 | 09:11 PM
  #40
brb getting cut
Also, what would you guys recommend, a 10.5 rear or 11"? Im almost set on the 10.5 because I know the offset I want,
but an 11" sounds so tempting.
Old Jan 17, 2008 | 09:36 PM
  #41
redlude97's Avatar
They are polished with a clear anodized coating. The difference between chrome and polished is the chrome is going to shine a little bit more, pictures won't really pick it up though
Old Jan 17, 2008 | 09:38 PM
  #42
redlude97's Avatar
11" is easy to fit, if you look at the vs-xx offset sheet PDF, you can get to 11" by simply changing the inner barrel piece with a piece 1/2" wider. You effectively don't change the outer position of the wheel, only how far the wheel extends into the fenderwell.
Old Jan 17, 2008 | 09:50 PM
  #43
brb getting cut
Thumbs up
^thanks.
Old Jan 22, 2008 | 07:21 PM
  #44
brb getting cut
Alright I just placed my order for the wheels! 19 x 9.5 F and 19 x 11 R.
They're gonna be wrapped in Falken 452's 245/35 and 285/35. I forgot the offsets though through all the excitement. lol. new thread to come when the wheels are on with the drop.
Old Jan 22, 2008 | 08:18 PM
  #45
redlude97's Avatar
Good choices except I would run a 255/35/19 in the front instead
