Offset to clear Brembo's
Old Dec 30, 2007 | 10:55 PM
DRA-G35-ON's Avatar
What up fellas. I have '06 coupe 6mt w/ brembos. I was just wondering if 32 offset would clear my brembos. Thanks!
Old Dec 30, 2007 | 11:51 PM
Triple8Sol's Avatar
Offset doesn't tell you much. It's also about rim diameter and spoke design. Search.
Old Dec 31, 2007 | 12:53 AM
jserman's Avatar
are the brembo's after market????
my 04 with brembo's are +25 on 20x8.5 and 20x10
Old Dec 31, 2007 | 12:56 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
it all depends on the wheel. If its a one piece cast wheel then it would need the right spoke design and you'd most likely need a spacer (the size of the spacer would depend on the width of the wheel)
If it's a 2 or 3 piece forged wheel then it would need the right pad type to clear a big brake kit.
-GP-
Old Dec 31, 2007 | 09:23 AM
DRA-G35-ON's Avatar
it's the factory brembos, 19 or 20 x 8.5 (f) x10 (r). Are there any disadvantages to adding a spacer?
Old Dec 31, 2007 | 09:27 AM
RBull's Avatar
Rated M
Yes, you're adding to stress on studs pushing the wheel out further from the hub.
Old Dec 31, 2007 | 10:04 AM
Gilley's Avatar
Do you have a set of wheels in mind? Most manufacturers or retailers with experience can tell you what will and won't clear the Brembos.
Old Dec 31, 2007 | 10:12 AM
Boston's Avatar
^ +1 A reputable retailer will be able to advise size and clearance for a specific wheel manufacturer that you have in mind. The offsets will differ by manufacturer and wheel type as mentioned.
Old Dec 31, 2007 | 01:28 PM
DRA-G35-ON's Avatar
So is it something that I shouldn't even consider?
Old Dec 31, 2007 | 03:26 PM
Gilley's Avatar
Not if you can avoid it, but a lot of people have installed spacers without any problems. The best way to purchase rims is to get ones that fit properly from the start.
Old Jan 1, 2008 | 04:38 PM
DRA-G35-ON's Avatar
Thanks Gilley. These are the rims I was lookin at. If I decided to go with these, what size spacers should I go with? They come in 19's and 20's, with the same offset.
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
seagrasser
May 3, 2022 09:43 AM
jilljann1
Jul 21, 2020 08:12 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
