06 Sedan: 20x8.5F and 20x10R what offsets?
I have a 2006 6MT sedan with the 18" sport wheels I am looking to get some 20" wheels.
Below is a list of the available offsets for the front and rear wheels I want.
I am looking to get the maximum wheel lip while still being able to have the tires fit inside the wheel wells without rubbing.
WHAT IS THE BEST OFFSET FOR FRONT AND REAR FOR A 06 SEDAN?
Front:
20x8.5 +20 offset
20x8.5 +35 offset
20x8.5 +45 offset
Rear:
20x10 +25 offset
20x10 +36 offset
Lowering Questions:
1. I do plan to lower the car about 1" or whatever slightly tucks the tire how will this affect choosing the correct offset?
2. Lowering the car pulls the wheels in right? so if your 20x10 is rubbing in the rear will lowering the car 1" pull the wheels inside just enough to eliminate the rubbing issue?
Tires Questions:
Front 245/35/20 will it work with all these offsets for the front without rubbing? +20, +35, +45?
Rear 275/30/20 will this tire work with all those offsets without rubbing? +25, +36
Thanks
Front:
20x8.5 +20 offset
20x8.5 +35 offset
20x8.5 +45 offset
Rear:
20x10 +25 offset
20x10 +36 offset
Lowering Questions:
Tires Questions:
Thanks
seagrasser
May 3, 2022 09:43 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
